"Hammer clearancing" for wheels?
Old Feb 18, 2005 | 03:15 PM
  #31
bruecksteve's Avatar
Re: "Hammer clearancing" for wheels?
I've autocrossed (using 315 Kumho V710's and Hoosier S03's) and run track days with them with no problem. If I was going to have a problem, it would have surfaced by now. I would probably think twice if I was running a 1/2" or larger but a 1/4" just isn't an issue.
Old Feb 18, 2005 | 03:18 PM
  #32
JasonD's Avatar
Admin Emeritus
You also had the longer studs, correct?
Old Apr 20, 2005 | 12:01 AM
  #33
johnny o's Avatar
Steve, you are running 17x11" on the front??? Did you have to do any mods to the front to fit 11" wide rims other then a 1/4" spacer??
Old Apr 20, 2005 | 06:08 AM
  #34
My front 17x11's are 36mm offset so I didn't have to do anything.
If you use a 50mm offset, you either need a spacer (1/4") or grind the little bump of the upper spindle arm.
Victor Lamb
Aug 26, 2017 02:52 PM
jasonduaine
Jun 4, 2015 09:29 AM
jackpawt883
May 20, 2015 06:53 AM
NJ SPEEDER
Jul 29, 2002 04:19 PM
Jim S. '95 Z28
Jul 25, 2002 11:58 AM
