5th Gen 2010/2011 20" wheels on 4th Gen Z28?
Old Mar 26, 2011 | 03:35 PM
JETMAN95Z28's Avatar
Has anyone ever tried to install a set of the newer series wheels and tires on an older 4th generation F. Body? Possible pictures?
Old Mar 26, 2011 | 08:47 PM
Re: 5th Gen 2010/2011 20" wheels on 4th Gen Z28?
Wrong bolt circle - 120mm - while the 4th Gens require 120.65mm.
Old Mar 26, 2011 | 10:28 PM
JakeRobb's Avatar
Super Moderator
Also, the 29" tire is a bit big for a 4th gen.
Old Jun 22, 2011 | 04:06 AM
slo2pro's Avatar
thats not enough to make a difference, they will bolt on with some machine work to the wheels. hub size is the big difference. the hub on the 4th gen is 2.25inch i believe, and the 5th gen has a 1.75 inch hub. so you will have to machine work done.(unless your good with a die grinder). if you use a 245/35/20 on the front and a 275/35/20 on the rear it shouldn't rub. that is the setup on my car currently.. anyway.. ill post a pic or 2 later on if i can
Old Jun 22, 2011 | 05:27 AM
It's a big enough difference to have caused broken wheel studs and loose lug nuts for people who have bolted BMW 120mm wheels to their 4th Gens. Some people have no problems, others do. In any case, its adding bending stress to the studs, which are designed for shear, not bending.
Old Jun 22, 2011 | 01:32 PM
slo2pro's Avatar
hmmm, well thats good to know..well no problems so far, i have had them on my car for about 5k miles now with no problems.. thank you for the information ill keep that in mind.
also here is a pic of my car.. lets see if this works..
sorry about the shotty camera phone pics..
https://www.camaroz28.com/forums/pic...pictureid=3951
Old Jun 22, 2011 | 01:35 PM
slo2pro's Avatar
check my pics.. this is what 5th gen wheels look like on a 4th gen... some people hate it(mostly people who dont see it in person) other people love it, its kinda a toss up, but i get compliments everyday.. its nice to have something different then everyone else though, thats what i like about them..
Old Jun 26, 2011 | 01:59 PM
Standard-z's Avatar
Heres another pic.
Jason Short
Jan 19, 2015 06:33 PM
4586
Dec 31, 2014 02:21 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
