stripped oil drain plug
Old Oct 13, 2010 | 03:46 PM
CAMBURT's Avatar
my 94 camaro oil drain plug is stripped, would a piggyback oil drain plug work and stop the oil from leaking. any help would be appreciated.
Old Oct 15, 2010 | 09:14 PM
byrons1502's Avatar
If its aluminum helicoil the pan. If its steel tap it out for a slightly larger bolt
Old Oct 16, 2010 | 12:51 AM
Evolution223's Avatar
helicoil would proably leak a little, plus you would have to drill and tap to put a helicoil in anyway, but if you got the tools it can be drilled and tapped. Would be easiest to buy the drill & tap, tap wrench and new plug and drill & tap or just take the pan off and take it somewhere to be fixed.
If you don;t know how to tap a steel hole by hand read about it online first, it's not hard but there's a correct way to do it so you don't break the tap. 1. use oil and 2. turn in to cut 1/2 turn of thread at a time and back it out 2 turns to clear chips and clean tap. Take your time. Use both hands on tap wrench to put even force on each side. It shouldn't take much force to cut the threads.
Either use a pipe thread or I think the factory uses regular thread with a bolt with a gasket washer on the head.
Magenta_Hearts
Mar 29, 2017 08:54 PM
eanhl2004
Apr 4, 2015 12:01 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
