fuel pressure
Old Aug 14, 2003 | 08:49 AM
camaros_4_lfe's Avatar
fuel pressure
what is the fuel pressure suposed to be at on a 3.4?
Old Mar 23, 2004 | 02:46 AM
LT1_PWRD-Z's Avatar
Question ? Fuel Pump Pressure on '98 4.3 engine?
Hello, I'm trying to help a friend of mine who may have a bad fuel pump, and figured I'd use this old thread.
She has a '99 Blazer with the 4.3 engine. I'm guessing that's the same engine as the V6 Camaros. I told her to get a Chilton's manual, but I want to know if anyone knows what the fuel pressure is?
Thanks in advance!!
Old Mar 23, 2004 | 02:48 AM
LT1_PWRD-Z's Avatar
Sorry, the Blazer is a 1999, not a 1998.
Thanks!
Old Mar 23, 2004 | 10:52 PM
LT1_PWRD-Z's Avatar
TTT
Someone has to have this information handy.
Thanks.
Old Mar 24, 2004 | 09:48 PM
Javelin3o4's Avatar
3.4 V6
FUEL SYSTEM PRESSURE 41-47 PSI(POUNDS PER SQUARE INCH)
POSITION THE IGNITION SWITCH AND THE A/C SYSTEM IN THEOFF POSITION. INSTALL A FUEL PRESSURE GAUGE TO THE VEHICLES FUEL RAIL OR FUEL PRESSURE TEST PORT. CONFIRM THAT NO LEAKS ARE PRESENT, AND VISUALLY VERIFY THE PSI READING ON THE GAUGE WITH THE IGNITION IN THE ON POSITION.
Autzone.com has this info just select your year,make,model,engine size and go to their repair/specifications section.
Old Mar 30, 2004 | 11:16 PM
LT1_PWRD-Z's Avatar
Thumbs up
Thank you so much for the GREAT info Javelin3o4!!!
The pressure in her blazer was between 48-55 PSIs. It doesn't matter if it's off with the switch open, or being revved up.
I thought is was a little high, but I guess her fuel pump is good.
She may have some gunk in her tank, because the mileage is really bad when she's low on gas, and so is the power.
I advised her not to let the fuel drop below 1/4 tank.
Thank again.
I really appreciate your time.
Later.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
