94 camaro vats problem
Old Apr 15, 2014 | 03:53 PM
S Leger's Avatar
just changed the ignition in my sons 94 camaro, the wires on the old ignition were broke, We installed a new ignition and got a new vats key, the car will turn over for a second ,then act like the vats keys isnt reading, the car will not turn over, then it will act like its working, it will turn over for a second but not start, repeat. i am wanting to bypass it{vats}, i checked the ohms reading on the key pellet and get 601, is this right? all charts i see do not show a 601 reading as an acceptable one? is my issue not the vats pellet ? thanks for ANY HELP
Old Apr 15, 2014 | 05:45 PM
GaryDoug's Avatar
Prominent Member
Re: 94 camaro vats problem
Are you sure it isn't reading 6.01K ohms (6010 ohms)? That would be a valid value. Nobody could have made you a key for 601 ohms. The ignition switch has nothing to do with the VATS value. That information is only stored in the VATS module or BCM if a newer car.
Old Apr 15, 2014 | 06:27 PM
S Leger's Avatar
yes, its is 6.01k i was reading on a 20 k ohm scale, i believe it is the ignition switch on the steering column, will try that,
Old Apr 15, 2014 | 08:43 PM
GaryDoug's Avatar
Prominent Member
As I am sure your know, the mounting hole slots on the switch are long, allowing a lot of adjustment. It may just need to be adjusted to be sync with the key lock. Trial and error is probably your best bet here.
Red Hawk 94
Mar 18, 2019 04:03 PM
bernie1951
Dec 10, 2014 10:03 AM
siguy
Nov 27, 2014 10:07 AM
Fedesna
Nov 23, 2014 11:06 AM
Chrisdude
Jul 24, 2002 02:25 PM
