1994 v6 3.4L 50mph service engine soon light
Old 10-10-2007, 08:47 PM
avie928's Avatar
i just bought a 1994 V6 3.4L camaro and i realized on the high way the sec i pass like 50, 55 or 60 the service engine soon light comes on. and when i turn it off and start it back up the service engine light is off and as i continue to drive its perfectly fine only when i pass 50 or 60 thats when it comes on again?? im clueless?? i need help bad.
avie928 is offline
Old 10-11-2007, 10:38 AM
350 HRSS's Avatar
It sounds like an EGR valve code, or maybe an 02 sensor.
You can get the code read at any local dealer, or anyone that has a scan tool.
Even though the light isn't on, it still stores the code. I believe it's 25 ignition turns.
Anyway, have it checked.
350 HRSS is offline
Old 10-13-2007, 09:06 PM
avie928's Avatar
i check the price on that part and its about $200 *XD but the one on my car looks new?? so what else do you think it could be if not that anyways this friday im going to have it hooked up to a computer at a dealer to find out whats wrong with it. i hope its nothing big
avie928 is offline
Old 10-14-2007, 12:22 PM
ford1's Avatar
any decent shop can check the code without going to the dealer for big $$ 40 to 60 bucks is fair for a scan.I believe a 94 is still the old ALDL under the dash that you can ground pin a to b and count the flashes of the check engine light to get the code.95 or 96 was the switch to OBD2
ford1 is offline
Old 10-16-2007, 09:53 PM
AlfredB18's Avatar
Not so.
Out of the 93-97 cars, only the 93 LT1's were able to ground pins...no v6 cars can do that.
AlfredB18 is offline
Old 10-18-2007, 05:13 PM
ImportKILLER's Avatar
Sounds like an EGR...mine did the same thing when it crapped out a few years back. It is a pretty pricey part but is very easy to replace.
I would suggest getting a OBD II reader though since it pays for itself in a few uses.
ImportKILLER is offline
Old 10-22-2007, 05:43 PM
avie928's Avatar
i bought the repair manual for the 94 camaro and it tells you how to clean it so im thinking of doing it and worst case i will have to change it but out of curiosity if thats the problem will that save me on gas??
also what type of exhaust do you guys recommend me to get to get a nice sound = )
avie928 is offline
Old 10-29-2007, 09:10 AM
ThunderboltZ28's Avatar
i would suggest a simple flowmaster muffler..i used to have a 95 v6 and it sounded pretty decent with a flowmaster
ThunderboltZ28 is offline
Old 11-05-2007, 06:06 AM
avie928's Avatar
well im finally going to go pick up my camaro from the mechanic today after work. he told me that the engine is fine and runs great i had him change the transmission filter and fuel filter plus transmission mount and a few more things. im going straight to the high way to see about that check engine.
avie928 is offline
Old 11-05-2007, 07:43 PM
avie928's Avatar
ok i finally got the car back and operantly they cannot find anything wrong with the engine they hooked it up to the computer and there is no error codes and the mechanic told me that he cant get an error code if the light doesnt stay on all the time. but what i noticed is you can go as fast as you want and its fine but as you slow down the second it hits the 60 mph mark the like comes on so im starting to think that maybe its has something to do with the transmission down shifting maybe?? i really donno what to think about it... what do you guys think???
avie928 is offline
Old 11-06-2007, 01:57 AM
95camaroinok's Avatar
Mine does the same exact thing, anything over 50 and let off the gas and the light comes on. Resets when you restart. Its the EGR valve, Try keeping just a little bit on the gas when you slow down off the highway. just enough to keep it from dropping clear to idle. I've been driving mine this way for a long time, one of these days I'll replace the manifold with the broken egr bolt stuck in it and make the light go away so I can quit left-foot braking. Dont worry about the trans if everything else seems fine, this CEL has nothing to do with your trans.
Edit- This is on my 95 3.4
95camaroinok is offline
Red Hawk 94
03-18-2019 04:03 PM
AdsoYo
05-02-2018 03:21 AM
10-31-2016 11:09 AM
Scottylt1
01-08-2015 02:48 PM
mspennyhughes
11-28-2014 03:22 PM
Quick Reply: 1994 v6 3.4L 50mph service engine soon light
