Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
Ams evo dyno video
Old Jul 1, 2005 | 08:25 PM
  #16
guywithaZ's Avatar
Re: Ams evo dyno video
The turbo lag on that is unreal...but boy does that ***** rev when she goes...I don't give a **** what anyone says that's an impressive car...
Old Jul 1, 2005 | 08:32 PM
  #17
80TA's Avatar
Not sure why it took so long to start spooling. If you use a two step to launch off the line you can build up boost and get off line much better.Or a stall in an auto turbo car.
Old Jul 1, 2005 | 09:06 PM
  #18
stereomandan's Avatar
Help me out here. Was he WOT the hole vid, or did he hit it at 3500 rpm?
35+ PSI is pretty impressive, but that's what totally sucks about 4 cylinders. You don't get decent acceleration in the normal daily driving RPM's (1500-3000 rpm). That's why turbo and SC V8's are such a blast. You have low RPM acceleration due to the V8 displacement and amazing top end due to the boost.
If that EVO is dedicated to 1/4 mile times, then props to him , but if it's a daily driver, then Driving that thing in it's boost range would be a MAJOR PITA.
Dan
Old Jul 1, 2005 | 09:09 PM
  #19
Originally Posted by 1QuickT-A
If thats the car I think it is, its a guy from Pensacola, Florida and its got well over 600whp! And its the same one thats spanking the **** out of every car it races.. Spanked a Procharged Z06 and a new Procharged Viper as well. Both cars had close to 700rwhp.. Its definately a mean lil ride, but still a import terd..
Seems like a tall tale since the Z06 weighs about the same as the EVO. If it was from a dig, then the AWD would help the EVO a ton, but if it was from a roll, then whoever has the most HP should win that race since the weight of the cars are nearly the same. 600 rwhp EVO vs 700 rwhp Z06 should tip in favor of the Z06 pretty heavily.
Dan
Old Jul 1, 2005 | 09:13 PM
  #20
Big Red Jim's Avatar
Dan
There's a video floating around of him beating a built and blown Z06.
Also - huge power in the lower rpms mean little when you have gearing....furthermore I don't know anyone who races from 1500-3000rpm. Everyone thought Bob Cosby was nuts for running 4.56 gears in his Cobra until they saw his results.
Old Jul 1, 2005 | 09:28 PM
  #21
80TA's Avatar
Off boost a 2.0 like stock talon can be pretty weak but the engines do rev fast. Also you can greatly drop full spool up rpm by going to bigger motor.For example 2.4 engine in dsm versus that stock 2.0. You can also use a few other tricks like lighter flywheel,open up the exhuast and intake,bigger maf ,heck we use gm mafs as mods in the dsm cars.
On the highway the lag is zero problem. You simply bang down a gear or two.An ls1 or lt1 is gutless in sixth gear too same idea.you bang down to fourth or fifth in your lt1 or ls1 or you lose highway races really badly too.
The turbo will then be at full spool with a downshift. Off the line in city driving huge turbos can suck a bit but a 2.4 engine with a bit higher compression than normal say around 9 to 1 gives pretty good off boost performance. And as I said to get more boost off the line you can use two step limiter. And there is even something called antilag that helps too. Most of the time you will use the two step for track and around town no big need to go into big boost off the line 99% of the time. Gas isn't cheap. If I want to launch super hard just use the two step.Problem solved.
I think the evo is running a GT35R .very big turbo. so some lag can be expected but these cars are also doing numbers like 140 mph in the quarter.Not too shabby. And you are right from a roll the awd is negated quite a bit.
Old Jul 1, 2005 | 11:41 PM
  #22
Jameslt1TA's Avatar
Originally Posted by BlackHatch
You guys are killing me. The anti-import sentiment on this board is out of control. You guys are worse than the civic owners that bash domestics for no apparent reason. A fast car is a fast car. I hardly think that a 600+rwhp EVO is being ricer.
Lol i think that the term ricer came from the car being imported from Japan...thus it must run on rice instead of gasoline. Most people call my little toyota pickup a ricer...i dont care it gets good gas mileage and still runs good with 220,000 on the clock.
Old Jul 2, 2005 | 07:54 AM
  #23
'88Saleen's Avatar
Originally Posted by Big Red Jim
Agreed. If this were a 600+rwhp Camaro dyno they'd be wetting themselves.
Camaros are cool muscle cars but no matter how much $$ you put into a evo it wont be a cool car. Is that the same evo that only ran 9.9 on the AMS site? I think its hillarious that a car (that evo) is creating such a uproar on here and the fact my car is faster.
_________________
'88 Saleen- 310cid ,Novi 2000,Fox lake twisted wedges,Dynamic C4
690RWHP and 650ft.lbs.
best et last year 9.6@146. shooting for low 9's @150+mph this summer
http://www.cardomain.com/ride/762099
'00 T/A- Hurst,MTI lid,pacesetter LT's,TSP ORY,Borla catback,baer eradispeed rotors,Hotchkis LCA's and torque arm,spec st. 3 clutch,SLP line lock,TTII's, Nitto Dr's, More mods to come!!
http://www.cardomain.com/ride/764642
"racing in a import is like the special olympics. You may win but your still retarded"
Old Jul 2, 2005 | 08:37 AM
  #24
Antz97ZNJ's Avatar
No anti import setiment here..could care less what I drive as long as it performs...Sorry but for the last mth or 2 these boards have been flooded w/ 600 hp evo vids killing vipers,supras,z06's etc...Think its hilarious when people bitch about the negative feedback about import posts on this site..but hey its a camaro board believe it or not there might be a few guys around here that hate yes I said hate imports...So either live w/ it or go hang out on import sites.
Old Jul 2, 2005 | 08:58 AM
  #25
Nope.
Old Jul 2, 2005 | 11:12 AM
  #26
Agreed. Does the original posted have the HP numbers correct though. Yes, low RPM TQ doesn't matter much when racing. HP does though. HP defines the top end, and if one car is hitting 700 rwhp and another is hitting 600 rwhp with similar weight, it's hard to imagine the 600 rwhp beating, let alone "spanking" the 700 rwhp car. Something doesn't add up.
As far as not racing from 1500-3000 rpm, you are just re-enforcing my point. I said that daily driving, that is where you are typically in RPM's, and it sucks if you have no power/torque in those RPM's since daily driving is what you do most of the time. You aren't WOT at 3500+ RPM's typically unless it is a dedicated 1/4 miler.
Dan
Old Jul 2, 2005 | 01:18 PM
  #27
85_305's Avatar
[QUOTE='88Saleen]Camaros are cool muscle cars but no matter how much $$ you put into a evo it wont be a cool car. Is that the same evo that only ran 9.9 on the AMS site? I think its hillarious that a car (that evo) is creating such a uproar on here and the fact my car is faster.
Ya really man. You have a freaking 17 year old car that would whoop that evo's ***, and you dont even get any special respect for it.
Old Jul 2, 2005 | 03:32 PM
  #28
That's because fast Mustangs are a dime a dozen. Fast imports still aren't (though they're catching up) quite there yet.
Seeing a 9 second import is still a less frequent site than a 9 second domestic, which is why it's noteworthy. Make sense?
Old Jul 2, 2005 | 03:39 PM
  #29
How much power do you really need from 1500-3000rpm? Are in that big of a hurry to get to 40mph? If that rpm range is what you care about, you may as well buy a diesel and embarass any f-body's "driveability."
Have you ever driven a modern turbo 4 cyl such as an Evo or even an SRT-4 like mine? I kind of doubt it based on your comments in this thread. I can assure you they're plenty driveable.
Old Jul 2, 2005 | 03:54 PM
  #30
drewstealth's Avatar
Well the reason the EVO gets so much attention is because it is beating the cars from a roll. Which is not it's strong point being a AWD. That and it is a 4cyl car doing it to force fed 8cyl cars also. But big red jim said it wasn't the same car so we don't know what that car runs in the quarter mile.
As for the daily driving of that car. I'm sure it isn't the best thing to drive around but I believe it is a 2.0 stroker which makes it a lot better in the low rpms. Also a 2.0ltr isn't really that bad on a 6 speed car even without the boost.
On my galant it isn't really without the boost and i have a 5 speed car with even less mods then that car. But it is no where near the low end power that my Camaro had.
