need help, grinding after wheel spacer install.
Old Jul 28, 2012 | 08:48 PM
ZX636RIDER03's Avatar
Just put on some 15mm spacers in the rear and now i'm getting a grinding noise when i slowly turn or take off. In order to re mount the rear brakes I had to add some washers and extended bolts to compensate for the spacers. Does any one know what might be causing this noise? I had used about 7 1/2inch washers to match the 15mm difference, anyone have any recommendations on a better way to do this?
Old Jul 29, 2012 | 09:50 AM
Re: need help, grinding after wheel spacer install.
In order to re mount the rear brakes I had to add some washers......
Are you saying you put the spacers BEHIND the rotors, and attempted to move the calipers outward using washers as spacers?
And these are 15mm (0.60") thick "spacers", using longer studs, and not "adapters" that bolt to your stock studs and have a new set of studs to mount the wheel?
Old Aug 5, 2012 | 10:18 AM
Still like to find out how you installed the spacers.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
akwa
Apr 5, 2015 05:09 PM
willie-d-nice
Feb 13, 2015 06:40 AM
