Which lca and rlb(if needed) do I need for my stock ride height for my 9 inch moser?
Old 07-29-2006, 10:16 PM
djm_e22's Avatar
I have a 96 z28 that I am about to put a moser 9 inch in. I really want some help with straight line traction with stock ride height. What do you recommend me do? I will be driving this daily but I will not be taking hard fast turns, so I want some mad straight line traction. So what bushing and lca's do you recommend for my 9 inch moser(if that even matters) with stock ride height? Also should I get relocation brackets? Could you also give me the brand you think I should go with? Thanks alot.
djm_e22 is offline
Old 07-31-2006, 08:20 PM
Severous01's Avatar
Re: Which lca and rlb(if needed) do I need for my stock ride height for my 9 inch moser?
if you're riding stock height you wont need brackets...other than the stock placement brackets. i'd suggest bushing/rod end combo sets to keep performance up and noise down. i built my own out of aluminum rod and jeggs rod ends and bushings i found on a website. some spare aluminum for spacers and it's done...cheaper than BMR could ever dream of. probably better parts too...and i know they're lighter. any way. unless you're running lowering springs you dont need the brackets.
Severous01 is offline
Old 08-01-2006, 11:11 AM
I've found that on higher HP applications, the LCA relocation brackets work wonders for straight line traction, even on cars that are not lowered.
The Moser rear axle assemblies require a different relo bracket than the stock rear or the Strange 12-bolt.
Injuneer is offline
HectorM52
Parts Wanted
02-11-2015 09:33 AM
ddr698
01-09-2015 10:05 AM
cmdeshon
12-12-2014 10:51 PM
NED4SPD
09-16-2002 10:45 PM
mjcent922
07-27-2002 12:42 PM
Quick Reply: Which lca and rlb(if needed) do I need for my stock ride height for my 9 inch moser?
