Which lca and rlb(if needed) do I need for my stock ride height for my 9 inch moser?
I have a 96 z28 that I am about to put a moser 9 inch in. I really want some help with straight line traction with stock ride height. What do you recommend me do? I will be driving this daily but I will not be taking hard fast turns, so I want some mad straight line traction. So what bushing and lca's do you recommend for my 9 inch moser(if that even matters) with stock ride height? Also should I get relocation brackets? Could you also give me the brand you think I should go with? Thanks alot.
Re: Which lca and rlb(if needed) do I need for my stock ride height for my 9 inch moser?
if you're riding stock height you wont need brackets...other than the stock placement brackets. i'd suggest bushing/rod end combo sets to keep performance up and noise down. i built my own out of aluminum rod and jeggs rod ends and bushings i found on a website. some spare aluminum for spacers and it's done...cheaper than BMR could ever dream of. probably better parts too...and i know they're lighter. any way. unless you're running lowering springs you dont need the brackets.
I've found that on higher HP applications, the LCA relocation brackets work wonders for straight line traction, even on cars that are not lowered.
The Moser rear axle assemblies require a different relo bracket than the stock rear or the Strange 12-bolt. |
