lca, and 2 point subframe connectors
Old Feb 9, 2007 | 10:28 AM
ajlew9428's Avatar
W/ mods in sig, I dont get any traction at all. Even if I take off at 1/4 throttle. Im planning on getting 2 point sfc's, and jm lca's. W/ these mods, how much will traction increas. I have stock wheels, w/ falcan ziex tires. Will it be pretty dramatic, or just a little bit. W/ my mods, should I get the 3 point sfc's, or would I be fine w/ 2? also, should I get a panhard bar as well. It is fun, but when it comes time to race, I cant hook worth a ****. I am planning on shocks, springs down the road, but not right now.
Old Feb 9, 2007 | 10:33 AM
2000GTP's Avatar
I have just about every suspension mod there is in the rear and I still don't get traction. There was a slight, noticable increase in the way the car bites the pavement, but in reality, its all in the tires. With street tires, you are just not going to hook up right away. As for the 2-point or 3-points, the 3-points on paper should offer more chassis rigidity, but you will most likely not notice a difference between the two. SFCs in general will be of a good benefit to your car in my opinion. As for the panhard rod, its probably not worth doing unless you plan on lowering the car or putting on some larger rear tires in which case an adjustable panhard rod may be of some benefit.
Old Feb 9, 2007 | 01:18 PM
ajlew9428's Avatar
thanks
Old Feb 9, 2007 | 02:43 PM
blue 79 Z/28's Avatar
lca relocation brackets will give you the most noticable difference with those mods, a must do IMO
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Jlo
Jul 29, 2015 03:52 PM
gelbza
Jul 12, 2015 08:10 AM
ducttape1975
Jul 10, 2015 06:29 PM
Boss002
Jul 9, 2015 03:33 PM
