Factory Rack, no pump?
Old Nov 15, 2006 | 12:35 PM
Vicious95Z28's Avatar
If you run the two lines together how good does it steer? What's the best way to accomplish this?
Old Nov 15, 2006 | 12:47 PM
Bolt-on Bob's Avatar
I'm investigating this now as I am going to delete my AC/PS and run SJM bracket to move the alternator lower. You need to call SJM; they were very friendly and knowledgable. Their suggestion was to keep the reservoir and lose the pump. The OEM rack needs the fluid as to not blow the seals out is my understanding.
Old Nov 15, 2006 | 01:25 PM
Projectz28's Avatar
Moderator
You can do it that way but you have to make sure its full of fluid. If you are half full you will hit air pockets and the steering will feel funny.
Other way is to just remove both lones, drain the rack by turning it lock to lock a few times (catching the fluid that comve out obviously) and capping them.
I run my car this way. Its rough but its a race car. If I have to turn other than at the end of the track the last think I am worried about is my rack
Old Nov 15, 2006 | 02:33 PM
are you running skinnies up front? Ineed to keep my 255's for a while till I can get some skinnies. How's that gonna be? I really don't want to keep the res. I wanna get rid of everything I can.
Old Nov 15, 2006 | 03:54 PM
Projectz28's Avatar
Moderator
yup, Hoosier front runners and everything is gone. Its not too bad honestly. As long as your moving the wheel isnt too hard to turn. If you stop, forget it. You really have to plan your turns.
Victor Lamb
Aug 26, 2017 02:52 PM
Jun 6, 2015 08:27 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
