Dual piston brakes?
Old Oct 14, 2004 | 08:36 PM
DuronClocker's Avatar
Dual piston brakes?
I have an '88 Trans Am with a rear end out of a '98 Trans Am convertible. Sadly, its a 2.73 like my stock 10-bolt was before I blew it. Anyways, my rear right brake has been making a lot of noise so I got the rotors re-cut. Didn't fix it, but it did fix the squeaking noise they were constantly making. Now it only squeaks when I hit the brakes on that side. When pulling everything apart, I found I couldn't press the piston in the caliper...even with no brake fluid (disconnected from line).
So anyways, I call up the local parts stores and Murray's tells me that they have a dual-piston caliper listed as the only one in stock for a '98 Trans Am's rear brakes. Not even an option for "performance brakes" so I didn't get it much. So I had them look up a Camaro of the same year and it listed a single piston caliper for a bit more money than the one listed for the Trans Am. ($44 vs. $35).
Did any cars have dual piston REAR brakes? Maybe he looked up the front even though I had him double-check. Did ALL '98 Trans Ams use dual-piston FRONT calipers, or just the WS6/SSs?
Old Oct 15, 2004 | 01:27 AM
85TransAm406's Avatar
Re: Dual piston brakes?
all 98+ f-bodies had the same discs, 2 piston front and single rears. They are, however, referred to as "LS1" brakes, referring to the body style.
Old Oct 17, 2004 | 11:24 AM
Hmmm maybe he looked up the front caliper then or something. Thanks for the info. I'll get that replaced ASAP then. If they had the option of dual-piston calipers, I was going to wait it out and upgrade both rears to dual-piston next spring. Thanks for the help
Firechicken350
Jun 6, 2015 11:25 PM
TitoPR221
May 26, 2015 12:20 AM
R@mpage
Apr 20, 2015 10:02 AM
bossco
Nov 29, 2014 10:18 AM
