adjustable coil overs help with ride height? also what lb springs in rear for drag?
Old Jan 17, 2009 | 10:44 PM
djm_e22's Avatar
Since I've installed the 9" rear end and did weight reduction in the ole LT1 camaro it now just rides too high. So if I get some QA1 adjustable coil overs I can lower the height of the car correct? Also I am going to first get the coil overs in the rear of the car first since it is extremely high in the back, what lb springs should I get for basically all drag racing, very little street?
Old Jan 18, 2009 | 05:07 AM
speedracer2j's Avatar
Spring Rate
Yes, coil overs will solve your ride height issue. Spohn is where I bought mine from, they, and everyone else has told me 150# rear springs for drag application.
Old Jan 18, 2009 | 05:31 PM
The quickest 4th Gen I ever had anything to do with (1.30 60-ft, low 8's at over 165 MPH) ran its best with my stock 94 Formula rear springs in it, and QA1 rear shocks. Car was a 97 SS convertible, but weight had been significantly reduced (3,500# with driver), so it was no heavier than a stock"ish" coupe.
cmdeshon
Dec 12, 2014 10:51 PM
thenewkid
Nov 27, 2014 09:41 AM
slothgrant
Aug 22, 2002 03:01 PM
regular Joe
Aug 8, 2002 03:47 PM
