Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
STOP Inside For Wilwood Brakes!
Old Sep 17, 2007 | 08:06 PM
tbyrne's Avatar
Talking STOP Inside For Wilwood Brakes!
Our new Everyday Low Pricing policy has allowed us to save you a little more $ on these packages. This covers any vehicle that they produce brakes for!
Kit Features:
Superlite 6 Big Brake Front Hat Kits are engineered for use in conjunction with OE front hubs on a variety of competition, show, custom, and sport driving applications. Billet Superlite 6 piston calipers, PolyMatrix brake pads, machined aluminum hats, and 13 or 14"" GT directional vane rotors exemplify award winning style and provide the ultimate in Big Brake stopping power. Born from Wilwood's 25 year tradition of building championship brake systems, SL6 Big Brake kits are the perfect compliment to wheel, tire, and suspension equipment upgrades.
Calipers Available in Black or Red:
SL6 calipers are pure performance featuring a fully CNC machined billet body with closed end bridges and a reinforced bridge to body transition. Center bridge body bolts provide additional strength and positive retention of the pads. These elements combine as an ultra-rigid body that resists separation and deflection under high load. Driver comfort and confidence soar with immediate response from a very firm pedal. The SL6 generates high clamping force and balanced pad loading from a race-proven differential bore six-piston configuration. Staggered piston sizes distribute pressure to compensate for the natural variances in temperature, load, and wear rate that occur over the length of the pad. Pad life is extended and performance is measurably improved. Stainless steel pistons are used in all custom show and sport performance applications for their low heat transfer properties and resistance to corrosion. Road race kits feature SL6/ST calipers with Thermlock® pistons for maximum heat protection in extreme heat environments. High temperature, square faced piston seals provide long service life in extreme environments with positive piston retraction on release. Stainless steel SRS bridge wear plates eliminate pad gouging and extend the service life of the caliper. The spring-loaded action of the SRS plates also eliminates pad rattle and dampens the vibration harmonics that contribute to pad squeal. Fluid tubes are dampened to eliminate vibration stress and recess mounted for protection from track debris. SL6 calipers bear Wilwood's signature and a high luster black anodized finish in a style that will catch the eye and win the favor of the most discriminating enthusiast.
GT aluminum hats are lightweight and strong to manage the exceptional brake torque generated by the SL6 Big Brake system. The hats are specially designed for use on OE hubs without modifications or interference to the suspension or ABS components. The hats carry Wilwood's signature and a high luster black anodized finish to prevent corrosion and enhance the overall appearance of the complete package inside the wheel
Large diameter vented iron rotors provide substantial increases in cooling and stopping power over small diameter OE rotors. All Wilwood rotors are manufactured from premium grade, long grain carbon iron to provide long wear with high thermal stability and resistance to distortion. The superior heat absorption and dissipation qualities of a directional vane iron rotor are essential to preventing heat fade and realizing the longest service life from the pads and rotors. For custom, show, and high performance sport driving, SRP rotor kits offer the high-tech look and improved performance of a directional cross-drill and face slot pattern. In addition to their aesthetic appeal, the venting and cleaning action of the holes and slots will reduce pad glaze, dissipate surface heat, and minimize irregular pad build-up on the rotor faces. The results are smoother engagement with improved consistency and response at the pedal. Every SRP rotor is treated with a silver zinc wash to reduce corrosion on the areas of the rotor not kept clean by pad contact. GT rotor kits feature Wilwood's ultimate competition rotor with full detail machining, asymmetrical face slotting and individual dynamic balancing. GT rotors run true and vibration free with extended rotor life and pad wear on applications subject to higher sustained operating temperatures.
PolyMatrix brake pads get fast response with high resistance to fade, long wear, and the low rotor abrasion that PolyMatrix is so well known for. Specific pad types and compounds have been selected for each application and are listed in the service parts guide for each kit.
Aluminum mount brackets are lightweight and strong. Each bracket is CNC machined for precise fit on each specific spindle. Grade 8 strength or higher nuts, bolts, studs, washers, and alignment shims are included with each kit.
Please give us a call at 1-877-4-TBYRNE (1-877-482-9763) or e-mail tbyrne@tbyrne.com to receive a quote for your vehicle.
Have a good day!
TBYRNE MOTORSPORTS LLC
ORDER LINE - 1-877-4-TBYRNE
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR WEEKLY SPECIALS! 20% OFF INSTALLATIONS BOOKED BY OCTOBER 31ST!!
Old Oct 19, 2007 | 09:00 AM
tbyrne's Avatar
The Wilwood specials are still going too!!!
May 1, 2015 01:14 PM
Biggiebound
Apr 23, 2015 08:50 AM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
Bill'sWS6
Aug 5, 2002 10:48 PM
