Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Brake Upgrade ???
Old Jul 30, 2002 | 04:13 PM
Bill'sWS6's Avatar
Question Brake Upgrade ???
Will just doing slotted or cross drilled rotors all the way around give me better stopping? Or, do I also need to upgrade the calipers too?
Can I go any bigger on the Rotor size with stock calipers?
I'm looking for the cheapest way to get better stopping power out of my car. I was hoping just changing the rotors (which need it) to slotted or cross drilled (Cross drilled or Slotted are better?) and new pads would give me better stopping power?
The brakes have 40,000 on them, just turned 40,000 yesterday. How many miles is normal out of brakes (with going to the striop and brake TQing too)?
Thanks,
Bill
Thanks,
Bill
Click here for my best strip time!
98 WS6, Nitto 315/35/17's,MAC Headders and Off Road Y-Pipe, Flowmaster American Thunder Catback, Vig 3200 Stall, TransGo Shift Kit, MTI Clear Lid, K&N Filter, TR55 NGK's, Taylor 8mm wires, EGR MOD & Other Free Mods. 12.84 @ 104.15 MPH 60ft 1.73.
Old Jul 30, 2002 | 04:59 PM
rod442's Avatar
Post
I noticed better feel outta my powerslot rotors F+R. I didn't even upgrade the pads like they recommend. The stockers looked good.
Old Jul 30, 2002 | 09:38 PM
2001-WS6's Avatar
Post
I'm not an expert but I suspect the rotors by themselves offer a minimal improvement in the first stop category. They may have slightly less rotational mass while having more mass in the fire path for heat transfer. The Cross drilled and slotting will vent the heat and dust better which means they will consistently stop better than stock under repeated heat cycling use. Am I right road racers?
The combination of those rotors and better than stock pads (Hawks & EBCs) will make a noticable difference on the first stop and follow up stopping capability.
The next step then is Wilwood or Baer 4 or 6 piston calipers with matched rotors which would really make the big difference. If you really have the cash, the Brembo fronts will stop you like you hit a wall.
Rick
Old Aug 3, 2002 | 02:50 PM
94bird's Avatar
Post
Since you already have LS1 front brakes, you should try the LG Motorsports front brake kit. It comes with a bracket, Corvette C5 rotors and calipers, and everything else you need.
http://www.lgmotorsports.com/
If you go to the autocrossing and road racing board you'll see plenty of posts referencing this kit if you do a search.
However, for street driving only the only thing I'd focus on is getting a good set of pads and tires. The LS1 brakes are very good for a street driver.
Mike Taylor
'94 Formula
Holley cold air, Borla downpipe, Walker UltraFlo catback, BMR STB, BMR PHR, Ground Control coilovers, Bilsteins, 16x9.5 Rikens, Hoosier 275/45/16 A3S03, G2 Torque Arm, Torsen T2R
Old Aug 4, 2002 | 01:00 AM
CamaroSS30th's Avatar
Post
I'm working on fabricating C5 brakes on my car.. I will keep you posted.. Est. price around $400.00
Jay
97 Camaro SS 30th Anniversary Convertible
Old Aug 5, 2002 | 09:32 PM
94bird's Avatar
Post
Jay,
I paid about $400 for my C5 brake setup and I bought some takeoff calipers, rotors and pads from a Vette owner locally who switched his all out for Z06 hardware after about 3000 miles. If you are estimating $400 for a bracket, rotors, calipers, pads, and associated hardware, new, that's a screaming deal. I wish you luck.
Old Aug 5, 2002 | 10:46 PM
Talking
I got a set of take off calipers, rotors, and pads with under 1000 mikes on them for $235 shipped. and brackets for around $100... If it all works out I might be able to hook some other people up with a set up for around the same price or at least point them in the right direction. I will keep you guys posted.
Jay
Old Aug 5, 2002 | 10:48 PM
Wink
oh.. BTW $235 was for front and back calipers, rotors and pads (all 4)
Jay
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Jazsun
Dec 29, 2014 12:14 PM
