95 roadmaster only has 20lbs fuel pressure
Its got a 5.7 lt1 engine. I don't hear the fuel pump but it has 20psi. How much should it have? Could the regulator be bad? The gas tank is full so I dread taking that out.
It COULD be the fuel filter but chances are it is the pump. Not sure were the pump is on the caprice/roadmasters. However if it is in the tank i bet the work to change it hurts a lot less then the $700 a shop would charge you.
Well I scanned it, no codes came up. It uses and old obd1 connector. We're gonna try the ignition module today and a new computer tommorow. We were told the ignition module is part of the FI system.
Well we figured it out, the tab on the electrical plug on the opti broke a few weeks ago. The wire got pulled out at some point while I was working on it. Plugged it in and it started right up, lol. But the fuel pump was bad.
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
