95 roadmaster only has 20lbs fuel pressure
Old Oct 31, 2008 | 12:13 PM
NeoSNK's Avatar
Its got a 5.7 lt1 engine. I don't hear the fuel pump but it has 20psi. How much should it have? Could the regulator be bad? The gas tank is full so I dread taking that out.
Old Oct 31, 2008 | 01:29 PM
93transam1234's Avatar
With the key on it should have around 35-40 PSI.
It COULD be the fuel filter but chances are it is the pump. Not sure were the pump is on the caprice/roadmasters. However if it is in the tank i bet the work to change it hurts a lot less then the $700 a shop would charge you.
Old Nov 1, 2008 | 07:18 AM
Could be a faulty fuel pressure regulator. Take the vacuum compensation line off the regulator and look for wet fuel.
Old Nov 1, 2008 | 04:26 PM
NeoSNK's Avatar
We put a new fuel pump in and we have 40lbs now. But theres no injector pulse. The injector fuses are good. Any ideas?
Old Nov 1, 2008 | 05:00 PM
Have you scanned it for codes? A missing low resolution pulse from the Opti optical sensor causes the PCM to shut down the fuel system including the pump and the injectors.
Old Nov 1, 2008 | 11:22 PM
NeoSNK's Avatar
I'm gonna scan it for codes tommorow. We just replaced the opti and it ran fine. Then it was hard to start for a few days. Now it won't start at all.
Old Nov 2, 2008 | 11:20 AM
NeoSNK's Avatar
Well I scanned it, no codes came up. It uses and old obd1 connector. We're gonna try the ignition module today and a new computer tommorow. We were told the ignition module is part of the FI system.
Old Nov 2, 2008 | 01:50 PM
NeoSNK's Avatar
Well we figured it out, the tab on the electrical plug on the opti broke a few weeks ago. The wire got pulled out at some point while I was working on it. Plugged it in and it started right up, lol. But the fuel pump was bad.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
