Cams
Re: Cams
What you specify here in this thread you MUST convey to a custom cam maker like Lloyd Elliot so that he can craft you something that is as close to what you really want as possible.
Re: Cams
I second this statement if you want to go this route first. It gives you an idea of whether or not you want more power which would then require the custom camshaft be made up AND you will already have 1.6 roller rockers installed to work with the custom cam. This is actually something I am considering doing for the future build on my LT1. If you do at some point decide to have your cylinder heads ported and port matched for performance, make sure you assert that you want port velocity to be maintained if not improved for your daily driving needs! It is a small thing I have learned doing the research I have been doing.
Re: Cams
Look at the first cam on the link posted above - “sleeper cam”, “smooth idle”, “improving HP and TQ everywhere”, “Idle-5800 RPM”. Or even the one right below it, as noted in the post immediately above.
LT1 Cam Info «
LT1 Cam Info «
