Cams
What would be recommended cam for day to day driving ( stock 6spd ) ? Help
Re: Cams
Re: Cams
Originally Posted by Michaels
(Post 7003273)
What you specify here in this thread you MUST convey to a custom cam maker like Lloyd Elliot so that he can craft you something that is as close to what you really want as possible. |
Re: Cams
Stock cam, change springs, 1.6 roller rockers. Drives like stock everyday with the power bump of a small cam change.
Re: Cams
Originally Posted by Germansheperd
(Post 7003288)
Re: Cams
(Post 7003273)
Re: Cams
the first cam in the link I posted in #2. Crane 10308 springs. Do not use LT4 springs on non LT4 valves. Those are hollow (sodium filled) and lighter than solid LT1 springs so LT4 springs with solid valves = no
Re: Cams
Look at the first cam on the link posted above - “sleeper cam”, “smooth idle”, “improving HP and TQ everywhere”, “Idle-5800 RPM”. Or even the one right below it, as noted in the post immediately above.
LT1 Cam Info « |
