ZFX Problem Help!
Re: ZFX Problem Help!
Originally Posted by Kevin V 2002 SS
Unless there was a bad batch or something, it dried out because it was either old or it wasn't sealed tightly and dried out. That is the only reasons I've heard of why the ZFX dries out, hardly Sal's problem, but he is so high on customer sevice he replaces them anyway. Try that with any other product.
So yeah, it is Sal's problem. So is the issues that people have been having with the new Zaino polishing compound when following the directions to the T.
Originally Posted by Threxx
What constitutes old? I've never seen an expiration date so I would expect the ZFX to stay good almost indefinitely, especially for the liquid crack price charged for it. Sounds like several people have had completely untouched bottles dry out - or even if they were partially used you can't just make the assumption that the customer failed to seal the container.
What exactly are the problems with Z-PC Fusion? I haven't heard of any.
Do a search.
It can easily add swirl marks instead of remove them unless you do it a certain way (which is not listed as a requirement on the instructions.
Do a search.
Do a search.
It doesn't matter if you work it front to back, side to side, etc. The important factor is working it fully.
Ha. That's called user error, not product error. You could state that fact about most any polish on the market. I've been using Z-PC for a while and never had that problem. If you correctly work the polish (so that it breaks down), there will be no problems...that's the exact same as any other polish out there.
I can't believe I'm arguing with a guy named ZaneO about Zaino.
If it bothers you, check around a little. I've been around the detailing scene (far beyond this site) for a while now, and I use tons of products other than Zaino.
Have a good day.
Magenta_Hearts
Mar 25, 2015 10:24 AM
