ZFX Problem Help!
Old Sep 22, 2005 | 04:52 PM
  #16
O-taka's Avatar
Re: ZFX Problem Help!
doesn't matter how tight you seal it, there's tons of air in the bottle w/ the ZFx cuz there's so little to begin with. it's like more expensive than gold by weight
Old Sep 22, 2005 | 05:01 PM
  #17
SScream's Avatar
Agreed. Again, use Z1.
Old Sep 22, 2005 | 05:15 PM
  #18
Threxx's Avatar
Originally Posted by Kevin V 2002 SS
Unless there was a bad batch or something, it dried out because it was either old or it wasn't sealed tightly and dried out. That is the only reasons I've heard of why the ZFX dries out, hardly Sal's problem, but he is so high on customer sevice he replaces them anyway. Try that with any other product.
What constitutes old? I've never seen an expiration date so I would expect the ZFX to stay good almost indefinitely, especially for the liquid crack price charged for it. Sounds like several people have had completely untouched bottles dry out - or even if they were partially used you can't just make the assumption that the customer failed to seal the container.
So yeah, it is Sal's problem. So is the issues that people have been having with the new Zaino polishing compound when following the directions to the T.
Old Sep 22, 2005 | 08:40 PM
  #19
ZaneO's Avatar
As I stated, and as stated on the Zaino website, ZFX has a shelf life of 18 months. Sal is very good about replacing any bad product (regardless of how long one has had it).
What exactly are the problems with Z-PC Fusion? I haven't heard of any.
Old Sep 23, 2005 | 12:07 AM
  #20
Threxx's Avatar
It can easily add swirl marks instead of remove them unless you do it a certain way (which is not listed as a requirement on the instructions.
Do a search.
Old Sep 23, 2005 | 01:01 AM
  #21
MustangEater82's Avatar
I would be extremely pissed if mine died out after 3 months or so...
but ehh mine is nearly 2 years old and been exposed to 90 degree heat or more in the garage.
Old Sep 23, 2005 | 09:34 AM
  #22
ZaneO's Avatar
Do a search.
Ha. That's called user error, not product error. You could state that fact about most any polish on the market. I've been using Z-PC for a while and never had that problem. If you correctly work the polish (so that it breaks down), there will be no problems...that's the exact same as any other polish out there.
It doesn't matter if you work it front to back, side to side, etc. The important factor is working it fully.
Old Sep 23, 2005 | 09:35 AM
  #23
Threxx's Avatar
The people who've been having problems have described their process and it was identical to if not above and beyond the instructions on the container.
I can't believe I'm arguing with a guy named ZaneO about Zaino.
Old Sep 23, 2005 | 09:48 AM
  #24
ZaneO's Avatar
I guess you missed the part where my name is Zane Oliver...
If it bothers you, check around a little. I've been around the detailing scene (far beyond this site) for a while now, and I use tons of products other than Zaino.
Have a good day.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
