Constant coolant light
Old Mar 9, 2016 | 10:56 PM
phil5's Avatar
I have a 94 Z28 5.7. The coolant light stays on while the temp gauge stays low (not hot) and the radiator level is fine. Any help. NJ
Old Mar 10, 2016 | 12:22 AM
Re: Constant coolant light
The coolant light indicates low level in the radiator. First verify the coolant is full in the radiator, and the system has been correctly bled of air. If you have verified the coolant is full:
Common problem. The coolant penetrates the coolant level switch on the back of the radiator end tank, right below the fill cap, and corrodes the printed circuit board. You can try cleaning the switch, but seldom fixes it. A replacement switch is available. You can temporarily turn off the dash light by unplugging the switch. Just be sure to check level frequently.
jhaase
3rd Gen / L98 Engine Tech
20
Oct 4, 2015 05:10 PM
Fatdog2
Apr 27, 2015 10:32 PM
warmeck
Apr 27, 2015 04:34 PM
Blood type Z28
Apr 8, 2015 11:34 PM
Fusion93Z
Jul 27, 2002 10:48 PM
