Mad Z tuning plus 100 shot
Old Mar 20, 2005 | 11:43 PM
YZF/LS1 Freak's Avatar
I have been buging Ion enough latley and figured I would post this hear.
I am going to run a 100 shot on my car for right now. No 150 untill I get a few more things.
I just got a PCM tune from Ion and did not select Nitrous because I did not know I would be on it. Does he advance the timing or leave it alone for N/A cars?
Any of you guys with his tuning run a 100 shot or better with no retard?
I am half tempted to sen dthe PCM back and have it updated for a 150 but wouldent it then pull timing at WOT no matter what?
Old Mar 21, 2005 | 09:48 AM
94Zpower's Avatar
Re: Mad Z tuning plus 100 shot
Usually most tuners advance the timing on NA Tunes,
I have a PCMforless NA tuner in my pcm and I am now running N20 with a retard box to solve the problem and all is running well, I suggest the Mallory Hy Fire 685 box because it has timing retard ,window switch, and rev limiter all in one.
I pulled 2* frommy pcm tune and it runs great on the dope.
Old Mar 21, 2005 | 10:12 AM
You don't want to "tune down" your NA tune to run nitrous. Leave it exactly the way it is, to maximize NA power. Do the tuning for your nitrous "externally".... jets control the A/F ratio, and an ignition/retard box takes care of the timing.
Old Mar 21, 2005 | 11:48 AM
I was thinking about a retard box so I think I will go that route.
Old Mar 21, 2005 | 08:25 PM
MarkyMark's Avatar
What all is needed to make that mallory hyfire 685 work? I too have an Ion tune and it isnt tuned for nitrous.
Old Mar 22, 2005 | 07:18 AM
94Zpower's Avatar
you just need the box and its not a must but I would suggest the plug and play harness from mallory also that way you just have to color match the wires and plug it in instaed of cutting and hacking up your stock harness,
after that just follow the instructions to operate it.
Old Mar 22, 2005 | 10:04 AM
MarkyMark's Avatar
where is the best place (cheapest) to get the Mallory?
Old Mar 22, 2005 | 12:57 PM
94Zpower's Avatar
I got mine at http://www.centuryperformance.com/de...UCT_ID=MAL-685
it was $220 and well worth it.
Old Mar 22, 2005 | 11:05 PM
I looked in Summit and Crane has a retard with a controller that mounts in the car, so does MSD, I like this idead because you can retart the engine really quick in the car and don't have to pop the hood to do it.
Everyones thoughts?
Old Mar 23, 2005 | 04:20 AM
bazzi's Avatar
i have msd digital 6. works awesome
Old Mar 23, 2005 | 07:08 AM
94Zpower's Avatar
yeah but doe st he crane and MSD dig 6 have a window switch??? nope.
Old Nov 20, 2005 | 02:49 AM
Daniel6718's Avatar
does the mallory 685 have the ability to pull timing only on the n20? or can i run optimal timing n/a and then pull 3 or 4 for the gas
Old Nov 20, 2005 | 08:35 AM
nfa's Avatar
nfa
Yes, the mallory can be set up to pull timing once you hit the spray.
Old Nov 20, 2005 | 09:32 AM
Cmr0z28's Avatar
Simple. Activate it with the WOT switch, which only gets power when the N2O activation switch is on.
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
slimdawson
Aug 25, 2002 10:10 PM
MBonZ28
Jul 30, 2002 11:42 AM
Black Sunshine/ 00SS
Jul 24, 2002 08:57 AM
MBonZ28
Jul 24, 2002 02:35 AM
