Inline fuel pumps and nitrous.....
You guys using aftermarked fuel pumps with your nitrous systems. Are you using inline pumps, or replacing the in tank pump, and if either, what type are you using? What kind of flow would you need with a 100 hp shot system on the LT1? Don't want to rely on my factory pump and just wondering what to do. Thanks.
Ken R. 95Z
Ken R. 95Z
Wet system or dry? Dry needs the inline pump to boost the pressure significantly. A wet system can be handled in a number of ways, including larger intank pump, add-on outboard (parallel) pump, or dedicated fuel cell, with its own pump.
The fuel cell idea is out- I don't want to have anything quite so blatant in the car.
