Hidden N20 Setup
Old Oct 8, 2005 | 10:14 AM
Heatmaker's Avatar
Advanced Member
Hidden N20 Setup
Anhone have pictures of thier Hidden N20... under the hood and bottle locations?
Old Oct 8, 2005 | 11:27 PM
stereomandan's Avatar
Re: Hidden N20 Setup
How can they take pictures if it's hidden. j/k
Dan
Old Oct 9, 2005 | 10:17 AM
brubble's Avatar
It's kind of hidden if you close your eyes or shut the hood. J/K
Not to many people might be willing to show you their tricks when it comes to hidden systems.
Old Oct 9, 2005 | 10:27 AM
Heatmaker's Avatar
Advanced Member
we're all soldiers fighting the same war... we sould help each other out.
Old Oct 10, 2005 | 07:22 PM
formula14.18's Avatar
get a zex wet system and mount it under your intake elbow
Old Oct 11, 2005 | 09:22 PM
Sneakin Deacon's Avatar
same war different sides...best i can say to you, is let them see what they want to see...if they want you to pull a bottle out of the car so they feel your not on the bottle...then pull a bottle out of the car for them.
Old Oct 12, 2005 | 12:22 AM
DavesLT1's Avatar
probably have to go with a dry system to bring down the amount of lines to conceal. you could put that sneeky pete system in the area where the spare tire tools are, probably want like a 2lb bottle instead of the 10oz bottle it comes with. alsoif you don't have traction control I heard someone say they used the box for the system and put the solenoids in and wired the on switch to where the TCS swiitch is on the dash above the radio.
Old Oct 19, 2005 | 03:33 PM
JDM-93_Z28's Avatar
Im considering N20 but i want a good place to hide it. My buddy has a zex wet system which i like....i might try to hide that underneath the intake elbow and try to hide the lines as best as possible. Any other suggestions? or places?
Old Oct 19, 2005 | 08:52 PM
Mikes 1994 z28's Avatar
Here is a reference guide to completely hidding your N20 set up: http://www.geocities.com/MotorCity/1920/nos.html
Old Oct 19, 2005 | 11:44 PM
Nitro Dave's Avatar
We build a completely hidden system.You would have to send us your intake and for 800.00 you would have a completely hidden system.
Dave
Old Oct 21, 2005 | 06:14 PM
JDM-93_Z28's Avatar
Nitro Dave, do you have any pics of this hidden system?? And details plz.
Old Oct 21, 2005 | 08:21 PM
93camaroLT1's Avatar
I think the best hidden N20 setup (dry kit) is mounting the bottle behind the bumper (where the bumper support normally is) and if it a dry kit just run the line from the bottle to solenoid (put this in a unnoticiable area) and then put the nozzle under the intake elbow and go through and slide a rubber hose over the braided stainless steel N20 line. I have seen this done but not in a F-body, so I don't know if your going to have enough clearance behind the bumper for sure, but it would be worth a shot.. only negative is that you are obviously going to have to take remove the rear bumper cover and take the bottle out when you are not planning on racing for obvious safety reasons..
Old Oct 21, 2005 | 10:23 PM
FireChicken1995's Avatar
iv seen a monifold where a guy pretty much put everything under it (wet direct port drilled in the runners under the intake) and at the back of the manifold he tapped out 2 holes and put AN fitting on for mounthing the nitrous and fuel lines ran the lines under the car and had the bottle under 2 fake 10" subs in the back of the car....... its weird i know but it worked donno if you can do it to a LT1 intake though
Old Oct 23, 2005 | 08:14 PM
Dave89IROC's Avatar
I have pics of this type of setup on a carb manifold, I'll look for pics
Old Oct 23, 2005 | 10:12 PM
yea i saw it on a TBI setup i have real pictures at home but im in korea right now so......
