fuel pump install???
Old Oct 21, 2004 | 10:34 AM
4SFEDZ's Avatar
Exclamation fuel pump install???
how many people have done the trap door method when changing a fuel pump? how hard is it what does it include and does anyone know any good web sites showing it done. i am installing a walbro. 94 z28. is this a good idea or bad idea?
thanks terry
Old Oct 21, 2004 | 11:20 AM
MarkyMark's Avatar
Re: fuel pump install???
if you post this in lt1 tech it will get way more replies....I know the fuel system has alot to do with nitrous, but there are lots more members who look at the lt1tech section than here.
Old Oct 21, 2004 | 11:51 AM
4SFEDZ's Avatar
thanks for the info
Old Oct 21, 2004 | 07:49 PM
Jay-Roll's Avatar
I did the trap door method. Very easy and fast. Took me all of about an hour before I had her fired back up. Yes do a search there are a couple good websites outlining exactly how to do it with pictures. Good luck.
Old Oct 24, 2004 | 05:21 AM
dmoor88's Avatar
trouse. are you seeing those dyno #'s with the mods in your sig or is there a mod missing?
Old Oct 24, 2004 | 10:16 AM
Question's Avatar
Trap door method? Is this were you cut a hole in your tank? Anyone have a picture install tech?
Old Oct 24, 2004 | 12:20 PM
RacinLT1's Avatar
trap door means cutting a hole in the floor right behind the rear seat. i did it on mine,and 3-4 friends have done it on thier fbodies. there are threads and pictures about this method in the LT1 tech section.
Old Oct 24, 2004 | 02:09 PM
http://www.taekwondoplus.org/z28/fuelpump.html
http://camaroz28.cardomain.com/memberpage/348183/9
Old Oct 24, 2004 | 02:26 PM
dmoor88's Avatar
when is it a good ideal to use such a method? just when youre changing the pump often or what?
Old Oct 24, 2004 | 03:13 PM
RacinLT1's Avatar
i didnt change it often,but i wasnt about to drop a 9" and take my borla apart and wrestle the tank out just to change fuel pumps.
Old Oct 25, 2004 | 06:04 PM
Jay-Roll's Avatar
Ditto, but I don't have a 9"
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
