can bottle be in cab with you?
Old Oct 23, 2006 | 07:59 PM
myslowcamaro's Avatar
for nhra rules, can the bottle be in arms reach in the cabin?
Old Oct 23, 2006 | 08:10 PM
Nitro Dave's Avatar
Re: can bottle be in cab with you?
Yes, I believe so. You will need a NHRA valve and Blow down tube.
Dave
Old Oct 23, 2006 | 09:02 PM
Yes, as long as you have the blowdown tube, and the system is installed in accord with the manufacturer's instructions. From NHRA Section 16, General Regulations, 1:6 FUEL / Nitrous Oxide:
..... All bottles must be securely mounted (may not use plastic brackets), stamped with minimum DOT-1800 pound rating, and identified as nitrous oxide. Nitrous oxide bottle(s) located in driver compartment must be equipped with a relief valve and vented outside of compartment. System must be commercially available and installed per manufacturer's recommendations. Commercially available, thermostatically controlled blanket-type warmer accepted. Any other external heating ofbottle(s) prohibited.
Quickss96
Jan 29, 2016 05:56 PM
weedog
Aug 15, 2015 08:23 PM
Chrisbequick
Aug 4, 2002 12:45 AM
93 LT1 Formula
Mar 26, 2002 03:50 PM
