Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
M12 is less than a couple of months away already!
Old Aug 30, 2007 | 07:21 PM
  #46
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
i will admit i know nothing about convertors. but wouldn't it be loose down low, as i would want it to flash up at higher rpms? like i said i know nothing about auto trans setups and going fast.
dan,
get a custom blanket made like i did.... done!
last visit wasn't to D&D, i had some work done that they couldn't do. i actually had Joe and Amber @ T56 rebuilds do some work for me in a huge pinch!!!
.....real cars have 3 pedals
Old Aug 30, 2007 | 07:46 PM
  #47
IrocSS85's Avatar
I have 3 pedals. but one is tucked under the carpet. :finger:
for a nitrous car, you need it to be pretty tight cause the nitrous will cause it to "loosen". the same exact affect a large cubic inch engine would have on a converter compared to a small block. it will stall HIGHER behind the bigger engine. so what would be rated at 4000 in a N/A application, will do what denny said, and flash higher off the line, under juice. his new converter is prolly rated at like 2000 rpm in N/A form.
Old Aug 30, 2007 | 10:28 PM
  #48
AutoRoc's Avatar
lashed, cold plugged, electric water pumped, race fueled, tire swapped, strapped, and loaded up Ah it's fun turning street car into track car...
Tanman, the converter is like a slipper clutch. You want that thing to be loose but you want it to grab HARD just before or near the TQ peak so that car moves out ASAP. Adding nitrous/TQ means the converter needs to be built with that extra harshness in mind. Getting it just right rarely happens with 1 shot. 5000NA/6000NO2 was too much slip. 3000NA/4000NO2 will be before the TQ peak on a small shot. Adding more jet will make the stall higher, maybe 4500/5000...Hopefully by that point I am nearing liftoff..
2 pedal touche
Old Aug 31, 2007 | 11:00 PM
  #49
AutoRoc's Avatar
10.43 @ 131.17 1.487 60ft. That backed up a 10.44 first pass.
pulling 7 degrees with a 150 jet. I went 4 rounds on the hose! too bad I was eliminated on the 2nd...ha Didn't watch for flash rpm but it definately didn't bog!
Old Sep 1, 2007 | 04:41 AM
  #50
AL SS590 M6's Avatar
Moderator
Sweet. Are you spraying off the line or delaying just a smidge?
Old Sep 1, 2007 | 01:29 PM
  #51
IrocSS85's Avatar
damn denny, thats kick *** times dude. did you get a chance to weigh your car? that thing must feel like a rocket sled. cant wait to see it at M12.
moparman
Mar 5, 2015 08:47 AM
Scottyboy
Feb 11, 2015 10:28 PM
NewsBot
Dec 3, 2014 12:30 PM
Z284ever
46
Jul 2, 2002 07:13 PM
