Your oil pressure?
Old Jul 16, 2003 | 11:40 AM
drewstealth's Avatar
Your oil pressure?
Just wondering what your oil pressure is at idle and while driving. Mine at idle is around the line right under half. While driving it is about at 1/2 to 3/4 the way up. Does that seem normal? I'm also using mobil 1 synthetic incase that makes any difference.
Old Jul 16, 2003 | 11:57 AM
MongooseZ's Avatar
Yep!
I have a '97. When it starts cold, It's about the 3/4 point.
Once reaching running temp it drops to a hair under the 1/2 point. Raise the revs though (not much) pressure back to 3/4.....
Anyone else?
Old Jul 16, 2003 | 11:58 AM
A search should find you plenty of responses. This is asked quite often.
Old Jul 16, 2003 | 11:59 AM
BUBBA's Avatar
97 around 40 at idle and between 40-60 cruise.
Don't know what I will see when I change to synthetic.
Old Jul 16, 2003 | 12:04 PM
Patman's Avatar
At idle in drive, once warmed up, I see about 18psi. On the highway at 70mph I see about 40psi, and even at full throttle it stays at 40psi.
On a cold start, it is about 55psi.
This is with 5w30 Schaeffer synthetic blend oil.
Old Jul 16, 2003 | 12:21 PM
K, thx for the replies i guess mine is about right then. I know i should of used the search button. I usually do though.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
