XE 230/236 Questions
Old Jul 2, 2003 | 09:34 PM
leadfoot94's Avatar
I have decided to go with teh XE 230/236 cam with 110LSA, and a 106ICL. I was told to go with Non-self aligning 1.6 RR's with guide plates, so is there any that you would personally recommend? Also is there a specific Timing chain you think would work well with the new cam?
Old Jul 2, 2003 | 11:00 PM
Z95m6's Avatar
go with comp pro mags Non SA. There are two choices for timing chains pretty much either you go with the extreme duty gm chain if you want the stock water pump, or you can go with a Cloyes double roller chain and a electric pump.
Old Jul 2, 2003 | 11:58 PM
96LT14u2Nv's Avatar
y no SA RR's? i am using crane gold race SA 1.6 RR's and love em.
n e way, i also went with the cloyers true double roller and CSI electric water pump.
Old Jul 3, 2003 | 09:45 AM
leadfoot94's Avatar
Did you have any issue with the valve cover clearance with the Pro Mags?Did they come with guideplates? And I probably will go with the Extreme-Duty chain now because I have heard some bad things about electric pumps.
Old Jul 3, 2003 | 10:29 AM
quicksilver97ta's Avatar
You do have to trim the v.c. inside with either SA or NSA 1.6 Comp rockers AFAIK. It's not difficult though, you can just trim with tin snips. Do a search and there will be a pic or two for it, or someone else could chime in and post a link. From what i have read, the NSA's w/ guideplates are more reliable with higher lifts and higher rev's. I got my guideplates from Cmotorsports, they make good package deals.
Old Jul 3, 2003 | 10:46 AM
ltlhomer's Avatar
Yep another vote for CMotorsports. I got almost all of my cam/head swap stuff from them for very good prices.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
slocody
Feb 10, 2003 01:04 PM
Black Sunshine/ 00SS
Aug 25, 2002 01:11 PM
Aug 13, 2002 01:34 AM
