Would this Work?
Old Apr 17, 2008 | 05:01 PM
Counted Out's Avatar
Would this Work?
Would taking the temperature of the water (when the Thermostat opens up) tell me what temperature thermostat I have?
Trying to find a lazy way to do this.
Old Apr 17, 2008 | 05:05 PM
The Engineer's Avatar
The factory thermostat is 180 degrees in an LT engine. Just drain the coolant down a few inches, remove it and check it. If you go to a 160, you should touch-up the PCM tuning.
WD
Old Apr 17, 2008 | 05:13 PM
WD
I thought the stock Thermostat was 192?
And I'm asking because I think the previous owner mite have changed it, but I'm not sure.
Old Apr 17, 2008 | 05:27 PM
No, it is 180°.
Old Apr 17, 2008 | 05:28 PM
I still have my 14-year old orginal t'stat in a box in the garage, and its clearly marked 180*.
Old Apr 17, 2008 | 06:23 PM
Yeah, it should look like this:
Old Apr 17, 2008 | 08:12 PM
sam pace's Avatar
With reverse cooling of the LT1 the temp gage will read 10 deg warmer.
so 180=190, 160=170.
Old Apr 17, 2008 | 10:50 PM
Okay, so I found out that the stock is 180, but will doing what I said (original post) work?
Old Apr 17, 2008 | 11:18 PM
If just after warm up and while cruising, the temp gauge needle sits between the bottom and the first tick, then it has a 160. If it is between the first and second tick, it's a 180. (this is on a 1993 gauge that has ticks at 1/8 increments-I am using your sig as reference for the year)
Old Apr 18, 2008 | 12:56 AM
Thank you. I'll check it tomorrow.
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
