Would having too much oil...
Old Aug 11, 2003 | 12:54 AM
Quick96Z's Avatar
Would having too much oil result in an oil leak? My car is about an 1/8 to 1/4 of an inch past the full mark on the dipstick, and i was just wondering if having a little bit too much oil would cause a leak. I am experiencing periodic puddles and i have checked all the common stuff (intake and rear main) and they seem to be allright. Are there any sensors on the drivers side of the car that are common to spring a leak (oil pressure sensor? or anything else). Any suggestions would be appreciated.
Thanks,
trav
Old Aug 11, 2003 | 12:56 AM
Quick96Z's Avatar
Also, do you think having that much extra oil in there is bad? Should i drain some out or just wait until the next oil change?
thanks,
trav
Old Aug 11, 2003 | 02:36 AM
BigBlue95Z's Avatar
Well, since draining some of the oil out is so EASY, you might as well do it. Drain VERY LITTLE at a time unless you have extra. As long as the pressure isn't too high, you should be OK.
Old Aug 11, 2003 | 03:24 AM
Patman's Avatar
That small amount over won't cause a problem. You could go 1/2qt over on these engines and be safe. Higher than that, and you could cause leaks, although mostly you'd probably just burn that extra real quick as it would get sucked through the PCV system.
Old Aug 11, 2003 | 10:45 AM
BUBBA's Avatar
Overfilling the oil can lead to crank dipping. The crank churns the oil into foam and reduces the effectiveness of the oiling system.
Depends on how much overfill.
adamvasconcello
Aug 29, 2013 11:42 AM
SSbaby
28
Jul 20, 2008 10:37 PM
hallbilly
Jun 11, 2005 04:44 PM
Heatmaker
Mar 13, 2005 04:50 PM
