won't start!
Old Apr 15, 2006 | 09:13 PM
black95z0122's Avatar
won't start!
After a long, pain full header install i relized i needed motor mounts. I just finished putting those in and i just bolted the starter back up and tried to start the car. the starter made some grinding noises and i stopped tring to start it. i took the starter back out check out the teath on the starter and they were fine so i bolted it back up and tried again. this time after a little grinding for a sec it started. i then tried to start it again later and it wouldn't start. it just clicked. so i thought it was the battery i hooked up a portable jumper and it did the same thing it just clicked. did i fry my starter? how can i tell?
Old Apr 15, 2006 | 09:39 PM
MyShibbyZ28's Avatar
Re: won't start!
You might have fried the solenoid contacts. My starter clicks when the battery is not fully charged, but if your battery is good then I think you probably fried the contacts.
Old Apr 15, 2006 | 09:41 PM
Re: won't start!
so what do i do now?
new starter?
Old Apr 16, 2006 | 01:05 PM
Re: won't start!
If its the soleniod can i just replace that or do i have to replace the starter?
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
