Wiring PCM <--> Cabin *Help*
Old Jul 7, 2004 | 07:19 PM
orbitalshock2k's Avatar
Exclamation Wiring PCM <--> Cabin *Help*
I posted this on General Tech, got a little help but not much. Has anyone ever wired something from the PCM to the cabin?
Basically what I'm doing is trying to set up possibly the first sucessful SAFC II controller in a LT1 Camaro, I ran a search and nobody seems to want to do it or wishes to go with PCM Tuning.
Anyways I need to hack into the ECU harness, whether it be the actual PCM or wiring that is located already in the cabin. I looked at some wiring schematics but it's like reading Greek.
Anyone who has done the man switch or any ECU wiring at all's help is greatly appreciated, I really want to make this work, and pave the way so others can do this if all goes well.
Thank you
PS This is same as gauge install I believe with the purple or purple/white wires
Old Jul 7, 2004 | 09:40 PM
texanmutt's Avatar
What is an SAFC II controller.
Old Jul 8, 2004 | 09:26 AM
Tom 97ss #25's Avatar
http://www.apexi-usa.com/electronics_safc.asp
Old Jul 8, 2004 | 09:51 AM
I have located what I need to do. I am hoping for the first sucessful installation on an F-Body (to my knowledge) for one of these. I assure you pics will be up by Sunday, as well as results.
Old Feb 17, 2008 | 10:18 PM
88IROC_Z's Avatar
so did this ever work?, I have an SAFC-II just sitting here from my other car and I have all the PCM wiring-So should I go for it or was it a failure?????
Old Feb 18, 2008 | 12:23 AM
Not sure if you noticed that this thread is ~4 years old and the OP has not posted any tech in a very long time. Good luck.
Old Feb 18, 2008 | 11:28 AM
orbitalshock2k's last post was in March of 2007. His admin profile shows some sort of "activity" on the account in August 2007.
Best way to get an answer would probably be e-mail, but his user preferences are set to not show his e-mail address.
Old Feb 21, 2008 | 06:30 PM
88IROC_Z's Avatar
Thanks I noticed this post was old but I was trying to get some answers-but now I plan to go obd1 with lt1edit, but thanks for the help.
ldtantlinger92
Jan 19, 2015 01:26 PM
Jan 5, 2015 07:14 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
kandied91z
Aug 6, 2002 01:18 AM
chewy41
Jul 28, 2002 11:20 PM
