OPTI to PCM wire?
Old Jul 30, 2002 | 05:37 PM
Brett 91 RS LT1's Avatar
Red face OPTI to PCM wire?
Whoah, tell me this is wrong.
pn 12130319 costs $67. I am hoping that it means the ENTIRE chassis wiring for the engine....
Because what I have in my hand is a foot long stretch of 4 wires that go to the opti from the PCM.
This piece connects with a large piece to the rest of the wiring at about mid-way back on the intake and the other end is that long connector that goes into the opti-spark itself on the upper passenger side.
Does anyone know the correct part number for this piece? Because even GM should only be listing it for about $25 and not the $116 I saw at gmpartsdirect.com
BTW - I need to replace it because the 4 pins at the end that go to the opti are corroded.... hence the cause for my #6 and #8 plugs not to be firing.... I hope!
'91 RS Camaro - red/black, '95 LT1-based 355 w/ the infamous red intake
'00 C5 Coupe - black/black coupe, 6-spd, factory polished rims.
Chewbacca is NOT dead!
bs.cz28.com
350.streetracing.org/lt1d.html
Old Jul 30, 2002 | 06:26 PM
jcobz28's Avatar
Thumbs down
Sorry bud, that's the ripoff price GM wants for that little stretch of wires and two connectors. I needed to replace mine because the wires were coming out of the connector on the opti end. Ended up ripping one of an LT1 in a junkyard.
95 Z28 - 524hp Supercharged 383
Old Jul 30, 2002 | 06:33 PM
Lightbulb
That is the right part # and price. I don't think it is going to fix the problem with only 2 cylinders not firing. You could be getting trouble codes from the opti and it might fix that, but sounds like you have a secondary ignition problem that is in the spark plugs, plug wires or opti cap and rotor section.
Rob B 95Z A4, !T96
Tech Page
Old Jul 30, 2002 | 06:46 PM
Markolc's Avatar
Post
Brett, that IS the correct price, actually better than average for that little stretch of wiring. You know, I did have one left over, but I had to tear it all up to connect the DFI harness to the new style opti.
BTW, of those 4 pins on the opti, there is nothing specific that has to do with the 6 or 8 cylinder. Since we pulled the #6 and 8 plugs and they were WHITE, that means you're getting spark, but no FUEL. I wasn't getting spark on my #6, and if you wanna see a BLACK plug, come over. That's the symptom of no spark.
1987 Flame Metallic Red IROC-Z Camaro. LT1 motor installed. http://home.attbi.com/~markolc
Old Jul 30, 2002 | 07:20 PM
Post
Well, I am going to try to clean up those ends before I buy a new stretch. And I DO have a new opti in there now, so maybe the problem has passed because the old one was corroded. With some luck you and I will get the car done on Sunday and fire it up after its.......almost 3 month hiadus.
Old Mar 12, 2003 | 10:02 PM
num's Avatar
num
hahaha, this is great. I have a `95 opti with the LONG plug on the 4-wire pigtail that goes to the ECM. I went to the dealership to purchase the pigtail in upstate NY and they quoted me $150. Even the parts guy laughed. I ended up stealing the plug from another `95. I got the wirepins that go inside the opti plug from autozone from another GM-type alternator plug ($3 a piece) and soldered my own pigtail together. Wow, $9 spent.
nikolt1
Feb 27, 2015 09:10 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 27, 2014 09:41 AM
