wierd problem with fuel pump/relay maybe?
Old May 18, 2010 | 09:55 AM
PowerAddict's Avatar
so, went to start my car the other day, and it cranked, but didn't hit a lick. Put some carb cleaner in the intake, it started, and I drove it the rest of the day. Shut it down and started it a few more times no problem too. But then, the same thing happened yesterday, and the same thing has happened today? I don't understand what could be the problem?
I just recently put in a fuel pump relay because the old one was bad, but obviously the new one works, it hasn't died or anyting on me, just won't start w/o carb cleaner if it sits for like 8 hours or more.
anyone ever heard of this?
h
Old May 18, 2010 | 10:19 AM
RamAir95TA's Avatar
I would get a fuel pressure gauge to diagnose the health of your fuel system if you suspect it is fuel-related.
Old May 18, 2010 | 12:39 PM
raroz28's Avatar
How old is your fuel filter?
Old May 20, 2010 | 11:35 PM
yeah, i've never done the fuel filter...not a bad suggestion. Last two day's it started okay. Wierd I know
I was mostly just wondering if this has happened to anyone else I guess...
Old May 21, 2010 | 10:55 AM
Slick-Z's Avatar
Usually in your case if it only happens when it sits for a while then you might have a slow fuel leak and you should invest in a fuel guage cause its a good investment if you dont already have one. Also a fuel filter usually will cause a rough start and hesitation under load due to not enough fuel getting past the filter fast enough. This is an easy fix and should be done a couple times a year. I waited about a year and a half one time and my car suddenly started gasping for fuel and was running slow and rough i changed out the filter and sludge just poured out. After that the car ran good. Just make sure that you look for and codes or lights on the dash when first starting it or maybe even a few miles down the road because the car might even gbe telling you whats wrong.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
