Why are guys converting a Super Victor? When this is out?
Old Oct 9, 2006 | 08:34 PM
FASTFATBOY's Avatar
http://www.edelbrock.com/automotive/...efi.html#29785
Did I miss something here? Seems like this is so much less brain damage.
BTW where are the center holes in this manifold?
David
Old Oct 10, 2006 | 02:57 AM
MaxLean's Avatar
Re: Why are guys converting a Super Victor? When this is out?
I've wondered that too. Too bad Edelbrock wont drill them with the Lt1 bolt pattern...
Old Oct 10, 2006 | 09:21 AM
fast 93 z's Avatar
I have the Victor EFI manifold. Car just put down 522 rwhp N/A with more tuning to be done. That is with an engine setup to run nitrous.
Tony S.
Old Oct 10, 2006 | 11:48 AM
MEAN LT1's Avatar
Tony S.
Very impressive. There needs to be more number like that around here.
Old Oct 10, 2006 | 12:02 PM
OldSStroker's Avatar
David
SuperVic is a better manifold than the VicE maniford the VicEFI is based on, especially in the 3500-7000 rpm range. If you saw them side-by-side you would see the differences.
Old Oct 10, 2006 | 12:18 PM
Colin91Z's Avatar
There was a thread fairly recently that discussed the same subject, check it out
http://web.camaross.com/forums/showt...ight=edelbrock
Old Oct 10, 2006 | 06:03 PM
FASTFATBOY's Avatar
Tony S.
Impressive!!! What did those heads flow?
David
Old Oct 10, 2006 | 07:22 PM
fast 93 z's Avatar
David
315 @ 650
Old Oct 10, 2006 | 09:27 PM
chrism400's Avatar
David
Question is, what kind of heads are they?
Old Oct 10, 2006 | 10:03 PM
fast 93 z's Avatar
AFR 227 LT4's bare castings ported, polished, and flowed by PortPros.
Old Oct 10, 2006 | 10:06 PM
chrism400's Avatar
YEEEEEOWZA!
FASTFATBOY's Avatar
CHris how heavy is your car? The times in sig are those all motor on pumpgas?
More info on your combo please.
David
Old Oct 10, 2006 | 10:44 PM
SStrokerAce's Avatar
David,
The reason I professionally don't like that casting over others is for a few reasons.
I got one in when I did a conversion for a customer:
The intake was heavy by about 10lbs.
It had no good way to produce a transition from the carb flange to the runners.
The lack of a divider wall extending into the plenum was bad for midrange TQ
The runner shape and length wasn't as optimum
The size of the ports was intended for use with smaller super stock ports, rather than the stuff you would see on high output strokers.
That intake went back and a Super Vic was converted and ported in it's place. Ended up going 8's so I think it worked out ok.
Bret
NewsBot
Jan 8, 2015 11:29 PM
bossco
Nov 29, 2014 10:18 AM
carcrazyQT
Sep 17, 2002 07:54 AM
carcrazyQT
Sep 3, 2002 02:51 PM
Red97LT1
Aug 7, 2002 05:45 PM
