Why are guys converting a Super Victor? When this is out?
http://www.edelbrock.com/automotive/...efi.html#29785
Did I miss something here? Seems like this is so much less brain damage.
BTW where are the center holes in this manifold?
David
David
Re: Why are guys converting a Super Victor? When this is out?
I have the Victor EFI manifold. Car just put down 522 rwhp N/A with more tuning to be done. That is with an engine setup to run nitrous.
Tony S.
Tony S.
Tony S.
Tony S.
David
David
There was a thread fairly recently that discussed the same subject, check it out
http://web.camaross.com/forums/showt...ight=edelbrock
Tony S.
Tony S.
Impressive!!! What did those heads flow?
David
Originally Posted by chrism400
Question is, what kind of heads are they?
CHris how heavy is your car? The times in sig are those all motor on pumpgas?
More info on your combo please.
David
David,
The reason I professionally don't like that casting over others is for a few reasons.
I got one in when I did a conversion for a customer:
The intake was heavy by about 10lbs.
It had no good way to produce a transition from the carb flange to the runners.
The lack of a divider wall extending into the plenum was bad for midrange TQ
The runner shape and length wasn't as optimum
The size of the ports was intended for use with smaller super stock ports, rather than the stuff you would see on high output strokers.
That intake went back and a Super Vic was converted and ported in it's place. Ended up going 8's so I think it worked out ok.
Bret
Bret
NewsBot
Jan 8, 2015 11:29 PM
bossco
Nov 29, 2014 10:18 AM
carcrazyQT
Sep 17, 2002 07:54 AM
