Who has LE3?
Old Mar 20, 2005 | 09:38 PM
blitz1029's Avatar
Who has LE3?
My le3 head and cam package is coming in soon and i just can't wait.
Who has the le3 and what kind of results did you get on your dyno or track results. I did try searching but found le1 and le2 results.
Old Mar 20, 2005 | 11:08 PM
Jon A's Avatar
Re: Who has LE3?
If everything goes as planned, I'll be putting my LE3 heads on next weekend. Should have dyno results shortly thereafter.
Old Mar 20, 2005 | 11:19 PM
ManicHaze's Avatar
Re: Who has LE3?
awesome. I'd like to see your numbers, an le setup of some type is more than likely in my future. I like to see all the dyno results I can, to help me make my decision.
Old Mar 20, 2005 | 11:33 PM
Zigroid's Avatar
Re: Who has LE3?
i do
the question you should ask is "who has LE3 installed?"
then i wouldnt be posting.
Old Mar 21, 2005 | 12:30 AM
SS MPSTR's Avatar
Re: Who has LE3?
TTT. I too would like to see dyno numbers supported by track numbers.
Anybody???
Old Mar 21, 2005 | 12:32 AM
blitz1029's Avatar
Re: Who has LE3?
Originally Posted by Zigroid
i do
So when are you taking it to the dyno/track?
Old Mar 21, 2005 | 12:36 AM
blitz1029's Avatar
Re: Who has LE3?
Sweet. Keep us updated.
Old Mar 21, 2005 | 10:31 AM
SStrokerAce's Avatar
Re: Who has LE3?
Blitz,
Did you get the full LE3 heads and cam kit and are you putting that on a stock bottom end?
Bret
Old Mar 21, 2005 | 03:52 PM
blitz1029's Avatar
Re: Who has LE3?
Originally Posted by SStrokerAce
Blitz,
Bret
No we are doing all forged 383 kit (11.8 to 1), LT's, comp cams pro mag nsa 1.6 roller rockers, Le ported intake, comp cams 7.150'' pushrods, Gm extreme duty timing set, and Melling oil pump. I havent ordered the lifters and clutch yet becuase im still deciding which one to go with. I've ordered all these parts...im just waiting for them to all come in just like my le3 head and cam package.
Old Mar 21, 2005 | 04:12 PM
1SlowFormula's Avatar
Re: Who has LE3?
Blitz,
Bret
Bret,
Just out of curiosity, why are you assking? Will this not work on a stock bottom end? I was thinking about it later on.
Old Mar 21, 2005 | 04:29 PM
Zigroid's Avatar
Re: Who has LE3?
when I get it installed. shes apart in the garage right now. I plan on having it done before august... I hope.
Old Mar 21, 2005 | 06:06 PM
Re: Who has LE3?
Originally Posted by 1SlowFormula
Bret,
You just want to check PTV clearance and make sure the cam is installed correctly. Lloyd and I have setup that package with some heafty springs to prevent valve float and bounce but you gotta make sure that the cam is installed correctly so the valves and pistons don't touch. It's much closer than most cam/head setups but is still in spec.
Most people unless they are going to build a 11.5-12:1 355 don't need a LE3 cam a LE2 package would work very well.
Bret
Firechicken350
Jun 6, 2015 11:25 PM
Red_94Formula
Jan 22, 2015 12:17 AM
djm_e22
May 30, 2005 11:28 PM
bunker
May 16, 2005 02:10 AM
blind527
Mar 26, 2005 11:58 AM
