Would it be smart to get this done all at once?
Old Mar 24, 2005 | 02:57 PM
blind527's Avatar
LE3 heads, LE2 cam
Moser 12 bolt rear end with upgraded Eaton Posi
FLP Stage 4-5 Transmission
Driveshaft
Wheels/Tires
Lowering Springs
Dynotune
Headers/y pipe with cats/cutout
Torque Converter
Fuel Injectors
Plugs/wires
Tranny cooler
Would it be smart to get that stuff done all at the same time? I was thinking about it, what would you guys think?
Old Mar 24, 2005 | 03:26 PM
slverbullet's Avatar
Re: Would it be smart to get this done all at once?
i did. with the exception of the auto tranny components. everything in the signature i did all at one time (well, over a period of 3 months...but didnt drive the car in between). i dont know that there was any real advantage to it. other than the fact that the car was completly stripped of all its drivetrain and made it easy to work on all the parts of the vehicle. i didnt have to cut into the fuel tank to put in the new fuel pump because i had already pulled out the rear for the swap. same with clutch and driveshaft, easy because the transmission was already out. pulled the whole engine out and it made it super easy to put everything back together and you can take your time with it a little more comfortably. i sat in my lawn furniture while cleaning the head bolt holes on the block for example . i think its a good idea personally. i had fun doing it and the surprise is even greater when you go for that first drive. its like a whole new car.
EDIT: we would have a similar setup if you did this, so let me know if you have any questions. i also have tons of bookmarked pages for walkthroughs as well that i could send you.
Old Mar 24, 2005 | 03:28 PM
blind527's Avatar
Man your cars mods are like exactly what I'm getting. How do the LE3 heads and LE2 cam work on your setup?
Old Mar 24, 2005 | 03:30 PM
well, considering ive only had it done a few days, i havent had the chance to really check it out. but i will tell you that is awesome. definitely go with it.
Old Mar 24, 2005 | 03:32 PM
BlownF1's Avatar
The next project car I do, I'm planning out, then doing all at once.
If you don't mind the added time/labor to continually put things on and take them back off later then I'd do them in stages...afterall, that is half the fun of working on a car. It's really up to you and your wallet. The advantage of doing things one at a time is you can see the affect it had and if you run into problems it's easier to isolate them, knowing that only 1 thing changed.
Old Mar 24, 2005 | 03:48 PM
blind527's Avatar
The only reason why I ask if it's ok to do these things at the same time is issues of breaking in the new parts. Like the transmission, the new rear end with new gears, the cam etc.
Old Mar 26, 2005 | 11:47 AM
BlownF1's Avatar
It'd be no different than a brand new car...
Old Mar 26, 2005 | 11:58 AM
LT1Squirrel's Avatar
i say go for it, you'd only have down time for one instance
Acct 23749
Dec 9, 2003 10:45 PM
formula king
Oct 10, 2003 06:12 AM
johnsocal
Jul 31, 2003 10:39 AM
johnsocal
Jul 1, 2003 04:05 AM
hates rice 24
Nov 25, 2002 01:03 PM
