Where'd you get your oil pan gasket?
Old May 18, 2007 | 07:18 PM
shock6906's Avatar
I've accidentally gotten myself into a project I wasn't expecting to undertake. I need to replace my oil pan gasket. I called Auto Zone, Advance Auto, Pep Boys, and Parks Auto Parts. All of them only carry the Fel-pro rubber gasket. I've read too many times (on this site, I might add) that they're pretty good about leaking and that cork was the way to go. Anyway, the parts department at my local dealer is closed for the night. Is that my only hope of getting a cork gasket or do you think I'll be out of luck there too?
Old May 18, 2007 | 07:49 PM
rskrause's Avatar
Moderator
I dunno, I like rubber for a pan gasket???
Rich
Old May 18, 2007 | 08:08 PM
mdacton's Avatar
why would you want cork? they are crap...
use the rubber, they key is to make sure everything is clean and you don't overtighten it
Old May 18, 2007 | 08:12 PM
wrd1972's Avatar
My Felpro rubber gasket fits very nice and snug to the pan. I have never liked cork.
Old May 18, 2007 | 09:23 PM
Dave89IROC's Avatar
I have never had a rubber gasket leak unless it was over 100K miles old
key is every surface dry, no oil, and a smear of RTV at the joints(block to rear main housing, and block to timing cover), just a small dab is plenty
Old May 19, 2007 | 01:23 AM
94CamaroZ28's Avatar
Yup, the Felpro works great, and I like the little pins they supply to help hold it in place. Clean the rails and pan, don't overtorque, just a dab ofRTV at the joints.
Old May 19, 2007 | 10:18 AM
jclark311's Avatar
Felpro gasket set from Rock Auto is 25.00,
Engine : Oil Pan Gasket Set
FEL-PRO Part # OS34500R
LT-1 engine; PermaDry® molded rubber gskt. incl.
Old May 19, 2007 | 11:09 AM
aboatguy's Avatar
I've used the Felpro one-piece oil pan gasket on a couple of projects and I've come to believe that it is far superior to the old cork gaskets I used back in the old days
Old May 19, 2007 | 11:30 AM
96capricemgr's Avatar
I would be amazed if you found cork crap for this motor.
Only cork gasket I think you could find for the whole car is for the tranny pan.
Reguardless cork is junk, I don't know where you heard otherwise, maybe some old flathead motor site.
Old May 19, 2007 | 01:13 PM
seawolf06's Avatar
Use the felpro. I put black rtv on all the corners and on the front and rear "humps" where the timing chain and rear main are. (top and bottom of the gasket) Hell, you prolly could put rtv all around if you wanted. Won't hurt anything as long as you let it dry sufficiently.
Old May 19, 2007 | 01:15 PM
shock6906's Avatar
I got the fel-pro. I'm in the midst of putting it in right now.
Old May 19, 2007 | 05:38 PM
97 RedSS's Avatar
Felpro here on my Canton..no issues
Old May 19, 2007 | 05:48 PM
lt1_z28_m6's Avatar
FelPro here also, been dry ever since!
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
