where to jack the motor from?
Im replacing my motor mounts , due to a header install, the drivers side is in just need to put the pass side on after the mounts. my question is where should i put the blocks to jack the motor up? some said under the accs. bracket by the crank but i dont know if it will balance. also which side should i start on? thanks
Re: where to jack the motor from?
Originally Posted by JJJ93z
anyone jack the motor up before? can i jack it under the oil pan?
good deal, thanks for the help. also does anyone know what size socket to use on that bolt , i tried std. but none seem to fit, and locating deep well metric will be a challenge.
Victor Lamb
Aug 26, 2017 02:52 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
