Where to find LT1 timing chain ???
Old Jul 17, 2006 | 10:26 AM
  #16
69z-28's Avatar
Re: Where to find LT1 timing chain ???
contraststriker,
so basically you delete WP drive from timing chain with electric WP(duh!) and you can use a normal true roller set like you would on any other small block?
Old Jul 17, 2006 | 10:37 AM
  #17
contraststriker's Avatar
Originally Posted by 69z-28
contraststriker,
Yes, for vented-style (pin-driven) optis this is true.
Old Jul 17, 2006 | 12:10 PM
  #18
12SCNDZ's Avatar
Originally Posted by SevenStars
Where did you get the oversized sprocket and would you happen to have the part number?
-Stephen
I got it directly from Cloyes. It's part number S505.
Frank
Old Jul 18, 2006 | 12:19 AM
  #19
EuroticCustoms's Avatar
If you're running a stock, or close to stock engine, I'd go with the AE Clevite timing set offered at Advance Auto Parts for $42.99. Unless you've got a lot of mods, you don't need anything more. A roller will benefit you if you're spinning 8-10K RPM's, or running boost, with an electric water pump, but at 5700 to 6000 and/or N/A, the stock will be fine.
I've owned 3 LT1's at around 100K and have yet to see a stocker worn beyond use, but have replaced anyway. The AE Clevite timing sets are as good, if not better, than the stock sets. And YES this is a HELLUVA price. If you don't have an Advance Auto Parts nearby, order directly from their website http://www.advanceautoparts.com.
If you're dead-set on a roller and have an electric water pump, they have a good price on the Lunati Plus Roller set as well -- $49.48
Feffman
Oct 9, 2015 05:42 AM
Queens94z28
Dec 20, 2014 09:11 PM
Ricardo
Nov 29, 2014 10:58 AM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
