Where are the drain plugs on the block?
Old Aug 3, 2007 | 12:13 PM
micfly83's Avatar
Me and my buddy are replacing the water pump right now
and we cant find the drain plugs on the block
we drained the radiator and have 4 bolts off the WP...
will we be ok without draining it?
Old Aug 3, 2007 | 12:29 PM
Romero155's Avatar
There are two drain plugs, one on the passenger side head that is the coolant temperature sensor and one on the passenger side block which is the knock sensor
Old Aug 3, 2007 | 12:30 PM
JWS6's Avatar
If you want to drain your block remove the knock sensor on the passenger side.
http://shbox.com/1/4th_gen_tech2.html#radflush
Old Aug 3, 2007 | 01:25 PM
The block drain for the driver's side is at the bottom of the block, near the motor mount, with a pipe plug in it. At least on an F-Body. Y-body will have a second knock sensor in that hole.
Magenta_Hearts
Mar 29, 2017 08:54 PM
eanhl2004
Apr 4, 2015 12:01 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
