where can i get a high pres oil pump and pickup
Old Jan 14, 2005 | 01:34 PM
Seal's Avatar
where can i get a high volume/pressure oil pump with a high pressure pickup or something as well...
does this mean now i need a canton oil pan too?
i'm getting all these cuz of this post
http://web.camaross.com/forums/showthread.php?t=332701
thx!
Old Jan 14, 2005 | 01:45 PM
Robs97Z28's Avatar
Re: where can i get a high pres oil pump and pickup
You would be better off using a stock pump with a white spring. There are tons of guys running with set up with very high hp #ers. Plus, if you stay with the stock pan, you won't have to worry about sucking air. With a high volume pump, the oil can't return fast enough and the pump will suck air at high RPMs.
part # for white spring: 3848911
Old Jan 14, 2005 | 01:49 PM
Seal's Avatar
what does that spring do?
Old Jan 14, 2005 | 11:15 PM
DarkKnightZ28's Avatar
Increase the pressure. The pump does not create pressure, only flow. It's the spring tension in the pressure regulator/relief valve that sets the max pressure.
Old Jan 15, 2005 | 08:08 AM
Seal, you have been asking lots of questions that could easily be answered with a search. The pump and pressure thing has been beat to death with part numbers and details posted many times.
Old Jan 15, 2005 | 02:26 PM
Seal's Avatar
like getting my crank grounded too much?
or where to get custom bearings?
hehe, i'm searching right now
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
