where can i get a high pres oil pump and pickup
where can i get a high volume/pressure oil pump with a high pressure pickup or something as well...
does this mean now i need a canton oil pan too?
i'm getting all these cuz of this post
http://web.camaross.com/forums/showthread.php?t=332701
thx!
thx!
Re: where can i get a high pres oil pump and pickup
You would be better off using a stock pump with a white spring. There are tons of guys running with set up with very high hp #ers. Plus, if you stay with the stock pan, you won't have to worry about sucking air. With a high volume pump, the oil can't return fast enough and the pump will suck air at high RPMs.
part # for white spring: 3848911
Seal, you have been asking lots of questions that could easily be answered with a search. The pump and pressure thing has been beat to death with part numbers and details posted many times.
or where to get custom bearings?
hehe, i'm searching right now
