Whats involved in removing a radiator?
Old Aug 21, 2003 | 12:14 PM
scoobysnax83's Avatar
Well, the questions in the subject. Thanks a lot everyone!
Old Aug 21, 2003 | 12:17 PM
kingman109's Avatar
it isnt too bad....have to drain it of course....if i remeber it was just a fe lines to take off and couple of bolts then it helps to remove fan and it unclips and slides out....
Old Aug 21, 2003 | 12:19 PM
so basically disconnect everything and then I should obviously see what need to come off? Whats the easiest way to remove the radiator cover thing. Mine is perfect and I don't want to scratch it all to hell with a screwdriver. Do they make a special tool to remove those plastic rivets?
Old Aug 21, 2003 | 01:06 PM
madwolf's Avatar
Arrow
Which radiator cover? If you're talking about the top one, with the stickers and such, then that's held in place by 3 bolts. (if I remember right, 10 mm)
To remove the radiator, you need to remove the top cover, then remove the fans (I take mine out through the bottom) then disconnect all hoses and if you have an A4, the 2 tranny fluid lines. That's about it.... oh, don't forget to disconnect the low coolant level sensor.
Old Aug 21, 2003 | 02:20 PM
kingman109's Avatar
i believe if those plastic things are what im thinking u use a pair of wire cutters to get them out...the wire cutters are angled inward so they slide underneath the lip of the "rivot" pulling it up till u can grab into the actually stem of the rivot and just pull it out
Old Aug 21, 2003 | 03:37 PM
Woo-Hoo
Woo Hoo Well, that couldn't have gone easier! I mean you disconnect everything and basically lift it out. Can I just by pass the oil cooler lines and connect a hose straight from the radiator to the water pump? I plan on decommissioning the oil cooler as soon as I figure out exactly what is needed to plug it all up. The worst part about the whole job was that the car was still hot doh and it was 91 degrees out ! Plus we ran 12 miles this morning for PT with my platoon! This has been the longest day ever. But I'm still happy. Thanks for all the help fellas!
Old Aug 21, 2003 | 03:44 PM
madwolf's Avatar
Re: Woo-Hoo
You sure can!
If you want the factory look, you could order part number 10197675 hose. This is for the bypass. (I just did this the other day too)
Old Aug 21, 2003 | 03:47 PM
Re: Re: Woo-Hoo
Originally posted by madwolf
You sure can!
Are both ends of the hose the same size, or close enough that a smaller hose can be forced onto an end. I believe I remember hearing that one is a tiny bit bigger than the other. I'm not too worried about the factory look. Just whatever works, for cheapest .... I know you said that you bypassed the lines, but did you go all the way and remove the cooler? And if so, what do I need to replace it so it doesn't leak?
Old Aug 21, 2003 | 03:52 PM
madwolf's Avatar
I actually went ALLLLLL the way and bypassed the old engine (on the left) with the oil cooler on it. The new one doesn't have it.
My post here will tell you everything you need to know.
Old Aug 21, 2003 | 04:51 PM
Its not the collant passages that clog, inside the sandwich there is a metal heat sink that the oil kind of filters through to cool it off, that cloggs with debris and the top of the motor doesnt get oil. First use a 5/8 hose to bypass it. I bought 3 feet and cut it to fit but i think 2 would do it. cant remember, it was a few months ago. Then you remove the big nut that holds the oil filter on. I think it was 1 1/8. or 1 1/16. Then you remove the 2 7/16s bolt/stud thinggys that hold the filter mount on, replace them with 2 bolts.
So.....is this the best description as to replacing it? If so next time I do oil, its coming off! Thanks for all the help. Any other pointers you can give me before I tackle this?
DirtyDaveW
Dec 1, 2016 05:37 PM
Fatdog2
Apr 27, 2015 10:32 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
