Will these headers work...PLEASE!!
Old Aug 20, 2003 | 10:09 PM
pennys58's Avatar
Exclamation Will these headers work...PLEASE!!
I need to know if these headers will work with an LT1. They are Hooker LT's 1 3/4 inch in and 3" out. The only problem, which I knew(but thought it was okay), is that the inlets are round and not rectangular. I bought them off a friend that said he had them on his LT1 and I just paid 250 for the coating. Will they be okay...Thanks a ton. The new engine is going in this weekend and I can't afford to buy new ones...nor can I WAIT and longer!!!!!
JOHN
Old Aug 20, 2003 | 11:44 PM
pennys58's Avatar
I hate to TTT this, but it is driving me crazy...I never up it within 24hrs., but this is driving me crazy thinking about have to spend another $500+and if I need to try to get other ones I need to get on it...what do you think?
JOHN
Old Aug 21, 2003 | 08:55 AM
EviLBoX's Avatar
Are they circles or ovals? From what I've seen the LT1 Hooker headers are an oval shape (kinda like "0"). If they're a circle then that sounds like headers made for the LS1. If that's the case I definitely wouldn't put them on.
Old Aug 21, 2003 | 09:16 AM
Amped96's Avatar
If they are made for an LS1 you will definately know it. The primaries wont even line up with your exhaust ports. LT1 has the traditional SBC alignment with the 2 middle ports next to each other. LS1 exhaust ports are evenly spaced apart.
Old Aug 21, 2003 | 09:36 AM
jim88iroc305's Avatar
Cool
http://web.camaross.com/forums/showt...hreadid=152031
in this thread is a link to heads I bought from BOOSTX
take a look at enlarged pic of heads and see if the ports match up by eye.
EDIT
link is shutterbug link.
goto link click pictures and select the cyllinder heads
good luck
Old Aug 21, 2003 | 11:58 AM
pennys58's Avatar
I'm going to take a head over to my dads house, where the headers are, and will try to line them up. He says they came off of his LT1 and they may be from a LT4...so I'll let you know if they line up. If they line up will they be okay? Thanks for the help.
JOHN
Old Aug 21, 2003 | 12:10 PM
bt95formula's Avatar
Maybe I am wrong but take the exhaust gasket you plan to use and match it to the head and then match it to the header to see what kind of fitment you will have. Just a thought
Old Aug 21, 2003 | 01:26 PM
Black_Z28's Avatar
If they look like a circle, then they're for a LS1. But if they are in a D shape, then they're for a LT1. I would do what the guy suggested. Get some LT1 exhaust gaskets and line them up with the headers.
Old Aug 21, 2003 | 04:53 PM
pennys58's Avatar
Everything lined up okay. Bolt holes were where they were suppose to go and the exhaust inlets on the header lined up the the exhuast outlets on the heads. I don't know what they're from, but he said he did use them on his LT1. I would have just taken the gasket and tried to line it up, but the gasket and heads are here and the headers are at my dads. Oh well, it all lines up...I spent too much on them to have to start over...especially since I'm dropping the new motor in on wed...FINALLY...after 4 months of waiting. Thanks guys.
JOHN
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
