Whats better 3/8 or 7/16?
Old Jan 17, 2009 | 01:20 AM
mrmint69's Avatar
What are the better push rods? I have the option of 3/8 and 7/16 and need to know the pros and cons. I will buy the roller rockers for what ever one is better. Thanks in advance.
Old Jan 17, 2009 | 08:50 AM
twcblackhand6970's Avatar
I'm getting 3/8" Chromoly PRs for my set up, seems to be popular.
Old Jan 17, 2009 | 09:17 AM
87bandit's Avatar
just make sure a larger than stock diameter pr isn't going to have trouble with your rockers
Old Jan 17, 2009 | 09:57 AM
MadMike 97 Z28's Avatar
1 piece hardened stock diameter PR's will provide more strength than you'll ever need unless you are building full out race car.
Old Jan 17, 2009 | 11:30 AM
1989TransAm's Avatar
Need more information on the motor. Cam specs, spring specs, rpm range etc. It would not hurt anything to go to a 3/8" pushrod. I will be using them on my build. By the way the new LS7 motor has 3/8" pushrods. GM must think there is something to them.
Old Jan 17, 2009 | 12:12 PM
ttop1986's Avatar
The rocker options of 3/8 and 7/16 are for the size of the stud. Get 3/8 if you are leaving the stock studs in. Get 7/16 if you plan on replacing the studs and get 7/16 studs.
Old Jan 17, 2009 | 01:40 PM
looks like chromoly 3/8" PRs then huh?
Old Jan 17, 2009 | 07:22 PM
sbs's Avatar
sbs
I think the OP is confused, and in turn the entire thread is confused...
Rocker studs, perhaps?
Old Jan 17, 2009 | 07:31 PM
Kevin Blown 95 TA's Avatar
Yeah, 3/8" pushrods are thick. Heavy pushrods can contribute to valve float if you don't have enough spring pressure. On a solid lifter or racing engine, maybe that is a good idea. Do you guys mean 5/16" pushrods and maybe 7/16" rocker studs and rocker arms?
Old Jan 17, 2009 | 09:18 PM
"Yeah, 3/8" pushrods are thick."
Not necessarily. Manton sells them with a .065" wall. Diameter plays the biggest role in pushrod stiffness than the thickness. Hmmmm I see the poster has a supercharger. Spintron testing has proven that the weight on the valve side contributes more to valve float than the weight on the pushrod side.
Z Power
Sep 19, 2015 11:19 PM
4586
Jul 31, 2015 06:03 PM
JCSWS6
Jul 19, 2015 06:47 PM
merim123
Mar 30, 2003 09:58 AM
foggerZ
Feb 20, 2003 10:34 PM
